Wonderbar judging question - NCRS Discussion Boards
  • Stewart A.
    • April 16, 2008
    • 1035
    When the the judges judge the interior and they get to the radio - wonderbar. Besides checking for operation, what do they look at. And do they go to the effort of checking under the dash for the speaker ? Stewy
  • Mike E.
    • February 28, 1975
    • 5140
    Re: Wonderbar judging question
    We will look under the dash, behind the console to affirm that it is the right configuration, etc., as well as check out the chrome, dial, etc. from the front. We'll also look up at the underside of the speaker to see if it is an original type of speaker by looking at the configuration of the stamped metal and if the transformer is there and right. We'll do what we can to see that you have the black and green wires from the radio joining that black and green wires from the speaker, and if they have the right connectors.
    • Jerry R.
      • March 1, 1999
      • 116
      Very helpful comments Mike! Here are some more questions I've been asked or wonder about myself.
      Does configuration of the speaker stamped metal refer to the hole pattern below the cone?
      Is the dust cover presence verified?
      Does 'right' speaker connectors simply refer to correct two pin connector structural shape or is color critical?
      How important is the presence of the ink stamped part number on the magnet back frame?
      Is the Wonderbar sensitivity switch function inspected in any manner?
      Last question, is there an impact for the absence of external paper labels and if they are placed in incorrect locations?
      Thanks very much for the input and to Stewy for initiating the subject!
      Jerry
        Much of what you ask will vary based on the specific knowledge of the judges you pull for interior work on a given day. So, it's not possible to give you an 'algorithm' of what's checked and what isn't checked...
        Some of the things you question (e.g. presence of grille cloth, specific rubber ink stamp, Etc.) are DARN hard to see/verify when the car is assembled.
        But, anyone doing a serious restoration would be pretty foolish NOT to install grille cloth onto the speaker. It had a purpose...keep airborne debris from falling through the holes in the speaker grille and then 'rattling' off the surface of the speaker's cone!
        • Stewart A.
          • April 16, 2008
          • 1035
          I was hoping that you wouldn't look that far up at the speaker. I haven't got a speaker and to find a paper speaker with the 1960 attached transformer is posing to be very difficult. I will keep looking. I have the correct antenna coming and the radio is ready for resto, now I have to find the speaker ? Stewy
            Depends on who judges the car, what they know, how aggressive they are in their inspection + how 'hungry' you are for points...
            • Stewart A.
              • April 16, 2008
              • 1035
              Will they take a bribe LOL
              • Jerry R.
                • March 1, 1999
                • 116
                Thanks Jack, that's the info I was fishing for.
                Jerry
