1960 Windshield Frame Fit? - NCRS Discussion Boards
+ More Options
Posts
  • Dick G.
    • May 31, 1988
    • 681
    My 1960 windshield frame has a gap outside of the wiper arm holes about 4-5 inches long.. Both sides are the same. My windshield glass has been broken for years. The frame is also old and unrestored. I am trying to get my frame to fit better to the body. I am doing a body-off. I have seen other straight-axles with this same gap problem. Again, the gap is only to the outside of each wiper arm hole. I have tried moving the frame every which way, but the same issue. I have added new frame weatherstrip. A small uniform gap is what I want. Any experience with this? Thanks DG
  • Don H.
    • December 1, 1981
    • 1500
    Re: 1960 Windshield Frame Fit?
    I think this is normal and the factory would put a putty in it. Did you check the judging manual? Don H.
    • Dick G.
      • May 31, 1988
      • 681
      I have not referred to the JG. Even if it is acceptable for these type of gaps, I will still try to make them look better, one way or another. Thanks for your reply. DG
        • 11698
        Actually I'd check the AIM to see what they might have done.
        I know this is not unusual. My solid axle source won't be back in town for a day or two if you don't have an answer by then. I know he's faced this and fixed it.
        Patrick
        • Dick G.
          • May 31, 1988
          • 681
          Patrick: Thanks for the reply. Please let me know what your source says. DG
          • Mike E.
            • February 28, 1975
            • 5153
            That is not normal--original cars without windshield replacement did not have that. I've had that problem a couple of times when I've replaced the windshield and then put the assembly back on the car. It has to do with how the lower stainless piece fits on the lower channel it rides on.
            It is a very frustrating a time-consuming process, but the only thing that I have found is to take it all back off, take it all apart, and refit that stainless on the lower channel.
            I don't have a clear recollection of how I finally got it to sit down farther on the channel--I do have a very clear recollection of the pain.
            • Dick G.
              • May 31, 1988
              • 681
              Thanks Mike. DG
