160 Thermostat - Good or Bad? - NCRS Discussion Boards
  • Jim T.
    • March 1, 1993
    • 5351
    Re: 160 Thermostat - Good or Bad?
    Martin (2781) the 204 is what I remember the last time I drove my 96. It is not a daily driver and it was just a 10 mile run and I did turn the air on initially but turned it off the last 7 miles. Most of trip was I-40 and highway.
    I did learn one trip when the ambient air was cool enough to just use the vent for cool air and during a traffic slow down on the interstate trip when stopped noticed the temp climbing. Turned on the air, the fans came on and the temp came down. Got going again at speed and turned off the air.
    I have it written somewhere what my oil and engine temp were on the interstate during hot weather.
    • Joe R.
      • May 31, 2006
      • 1822
      Is there any advantage from a detonation standpoint to using a lower degree thermostat?
      Joe
        • 15640
        #18
        Yes, lower coolant temperatures will reduce the propensity to detonate (as does lower inlet air temperature), but I can't quantify it, The effect is relatively minor and it varies with engine design.
        However, given the mostly bad consequences of running a 160 degree thermostat, I certainly don't recommend it.
        Solve detonation problems with ignition map tuning and a thicker head gasket if all else fails.
        • Joe R.
          • May 31, 2006
          • 1822
          #19
          Would this one be a good choice for a '66 L-72 (427 /425) and probably other big blocks?
          http://www.napaonline.com/MasterPage...stat+-+Premium
          Joe
          • Joe R.
            • May 31, 2006
            • 1822
            #20
            Here's a link to NAPA's offerings for a '66 BB:
            http://www.napaonline.com/MasterPage...d=5&SubCatId=1
            I wasn't sure which one to pick. There is more than one 180 degree thermostat. To add to my confusion they say that 195 degrees is what the O.E.M. specified.
            Joe
              Joe
              Joe -
              Only with K-19.
              • Wayne M.
                • March 1, 1980
                • 6414
                #22
                ...However, given the mostly bad consequences of running a 160 degree thermostat, I certainly don't recommend it.
                So what am I supposed to do now with my "stash" of 160's ?
                  Put 'em in the "C3 Parts For Sale" section over on CF - they'll go like hotcakes!
                    • 15640
                    #24
                    Yeah, that's what I was thinking - those morons over there...
                    And, Wayne - sweeten the deal with some four dollar a quart boutique engine oil, some boutique oil and gasoline additives, some big "double pumper" Holley carbs, and some real narrow LSA camshafts.
                    "Tha's right, boy, I got me a real race motor 'n I only use the best oil 'n additives 'n the biggest cam 'n double pumper on the planet. Boy, it sure sound' good idlin' through the parkin' lot."
                      • 43202
                      #25
                      Joe -
                      Only with K-19.
                      John-----
                      Yes, the 195 degree thermostats were generally applicable only to cars equipped with the air injection reactor system right through the C3 years. However, I do recommend changing those to 180 degree (but NOT to 160 degree).
