67 jack hold down spring - NCRS Discussion Boards
  • Dale S.
    • November 12, 2007
    • 1224
    Is the jack hold down spring black phospated? Thank you Dale
  • Rick S.
    • January 1, 2003
    • 1203
    Re: 67 jack hold down spring
    Dale,
    The 1993 JM (extra one at home) says the spring is painted gloss black which I think the current JM also states. What loop do you have on your hold down spring, single or double. The JM calls for a double, but what I believe to original for my 67, it is a single loop.
    Rick
    • Gary B.
      • February 1, 1997
      • 7064
      66 jack hold down
      Rick,
      I can tell you that my late July build date '66 has the original spring/hook and it is the single-side hook style. I think the '66 JG is also wrong on this point.
      Gary
      • Dale S.
        • November 12, 2007
        • 1224
        My march 30th 67 has a rusty double hook. Dale
        • Kirk M.
          • June 30, 2006
          • 1036
          My April 67 has a double hook. Are we starting a trend here?
          Kirk
          • Francis F.
            • April 1, 1978
            • 420
            I can tell you my june 66 coupe has a single hook
            on the hold down spring
            francis
            • Brian M.
              • February 1, 1997
              • 1840
              My first week of Jan has a double hook.
              • Harry S.
                • July 31, 2002
                • 5342
                Best I can recall 66 was mixed between 1 and 2 hooks and all of 67 was two hooks. Saying that all 63, 64 and 65's had one hook as best I can remember.
                • Bill I.
                  • January 29, 2008
                  • 554
                  My 67, build 3/21, has a double. Bill
                  • Glenn S.
                    Infrequent User
                    • August 13, 2007
                    • 6
                    My 67 build date of 4/24 has a double
                    • Stephen L.
                      • May 31, 1984
                      • 3162
                      My 67 Has a double hook, Apil 10 build
                      • William L.
                        • December 1, 1988
                        • 944
                        My June 23ed 67 has a double hook.
                        Bill Lacy
                        1998 Indy Pacecar
                        • Pete L.
                          Infrequent User
                          • July 31, 2001
                          • 12
                          I see that the 66 Tech Manual indicates the "Jack Retainer" (should be "Spring Asm") is a single loop. The 66 AIM on page F217 shows a double hook spring, which is what my Nov. 65 has. Which is correct??
                          • Jake D.
                            • August 31, 1984
                            • 134
                            March, 4th--double hook.
                            • Rick S.
                              • January 1, 2003
                              • 1203
                              Well, looks like my June 67 with its single hook has had its jack retainer replaced at some point in its life. Funny that after finding so many original things on my car that you find something so insignificant that is not likely original.
                              Rick
