Need help on 1957 voltage regulator - NCRS Discussion Boards
  • Joseph T.
    • April 30, 1976
    • 2074
    Can someone post pictures of a genuine 1957 Corvette Voltage regulator including the month/date, voltage and correct vintage part # as stamped on the flange?
    Also what is the correct amp of the 57 voltage regulator?
    Did the FI cars use the same voltage regulator and same amp power as the lower HP cars?
    Many thanks,
    Joe
  • Gary C.
    Administrator
    • October 1, 1982
    • 17968
    Re: Need help on 1957 voltage regulator
    Joe, all the factory installed 57 voltage regulators have part numbers that are in a straight line. 57 voltage regulators with part number in two lines are considered service replacement regulators. Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Joseph T.
      • April 30, 1976
      • 2074
      Gary
      Thank you!
      Joe
