More 56 questions - NCRS Discussion Boards
More 56 questions
+ More Options
Posts
  • Edward M.
    • November 1, 1985
    • 1922
    More 56 questions
    OK, I finally located the Chevrolet Bulletin dated April 6, 1956 that announced RPO 469 as the optional two four barrel engine, and made the single four barrel engine the base motor.
    I have come across something else that is puzzling. The Automobile Manufacturers Association Consolidated Specification Questionaire, Issued 1-6-56, Revised 7-9-56 has the following information:
    Drive Unit - Convential Transmission
    Transmission Ratios:
    1st gear: 2.94:1 @
    2nd gear: 1.68:1 @
    3rd gear: Direct @
    Reverse: 2.94:1 @
    @ Optional transmission: First 2.2, Second 1.31, third direct drive, reverse 2.2
    Does anyone know anything about this optional transimssion? I never realized this info was there before.
  • Scott S.
    • March 1, 1979
    • 747
    Re: More 56 questions
    Ed, All 1956 Corvettes came with he Close ratio 2.20 first gear. Most will do 65 mph in second.
    Scott
    • Gary C.
      Administrator
      • October 1, 1982
      • 17864
      Ed, please refer to the "1955-62 Corvette Three Speed Transmission Spelled Performance" Restorer article by Paul Henricksen & Stan Edmunds. The gear ratios you've listed are the Corvette close-ratio gears. There were no optional gears for 56-7 Corvettes, just the close-ratio gears according to Paul & Stan. Gary....
      NCRS Texas Chapter
      https://www.ncrstexas.org/
      • Mike M.
        • May 31, 1974
        • 8404
        2.94:1 is almost certainly the standard or base pass car first gear ratio. don't believe these wide ration 3 speeds saw any c-1 vette application, just most pass cars. my 57 250HP 210 sedan's original 3 speed is a close ratio tranny but its an exception for pass cars in the shoebox era.mike
        • Edward M.
          • November 1, 1985
          • 1922
          Do we know this ALL 56 Corvettes had this 2.20 ratio transmission, even the single four barrel cars? I am still wondering about the AMA document.
            Ed -
            Colvin's CBTN agrees - it calls out the close-ratio gearing for '55-'60 Saginaw 3-speeds (2.20, 1.31, 1.00, R2.20).
            • Edward M.
              • November 1, 1985
              • 1922
              OK, I'm convinced. Thanks.
