I need to replace the hood hinges as one side is damaged and wondered if there were any recommendations. I see Corvette Central sells repro units, but I want it to remain very original. Also, the hinges on my car are painted a non glossy flat black. Is this correct for a Top Flight car?
Also, the pop up springs on the front of the hood are butchered. It looks like someone cut coils out of them. On one side the spring was cut too much and isn't working at all while the other side is apparently too stiff. Is there a replacement spring available or a good source for replacement pop-ups with the proper spring?
Thanks!
Thanks!
