66 4sp-shifter - NCRS Discussion Boards
66 4sp-shifter
  • John C.
    • May 31, 1993
    • 72
    66 4sp-shifter
    I'm trying to find out if some early 66 cars still had the shifter mounted to the transmission instead of the frame. The frame on the car I'm doing has the two holes in the rear of the cross member but does not look like it ever had any bolts in it (no threads). The car was built 12-8-65.
    John
  • Michael H.
    • January 29, 2008
    • 7477
    Re: 66 4sp-shifter
    John
    John,
    Your transmission mounted shifter is probably correct for your early 66. The change to a crossmember mounted shifter occured some time in 1966 but I believe it was somewhere around mid production??
    I have the GM paperwork and date that this change occured and when/if I find it, I'll post it.
    Just found it........
    • John C.
      • May 31, 1993
      • 72
      Re: 66 4sp-shifter
      Thanks Michael
      You guys are really a big help.
      Thanks again
      John
      • John L.
        • 409
        Re: 66 4sp-shifter
        I have a Dec 65 car and the shifter is mounted to the trans.
        • Michael G.
          • January 1, 1997
          • 1251
          Re: 66 4sp-shifter
          Sept. 23rd '65 build date on my '66 roadster....no shifter bracket on frame. Shifter mounted to tranny with mounting plate.
          Michael G.
          28614
          • Gary B.
            • February 1, 1997
            • 7065
            66 4sp-shifter; frame mount from VIN ~ 17,161
            Based on the 3-21-66 date in the GM Tech Service Bulletin announcing the next day change-over, cars with VINs of approximately 17,161 (first car with a 3-22-66 birthdate according to the C2 Corvette registry) and higher would have the shifter mounted to the frame. Of course, there is some accepted uncertainty in the birthdate calculator, so the 17161 VIN is just an estimate.
            Gary
            • Robert T.
              • May 31, 1993
              • 346
              Re: 66 4sp-shifter
              Hey Michael,
              My car is also a Sept 23, 1965 build. Mine's a coupe, s/n 1478. Yours must be real close to that.
              Bob #22650
              • Steven S.
                • August 29, 2007
                • 571
                Re: 66 4sp-shifter
                So if the owner took it in under warranty and complained of this shifter rattle would they have reloacated it to crossmember?
                Steve
                • Ron R.
                  Infrequent User
                  • January 31, 2007
                  • 18
                  Re: 66 4sp-shifter
                  My survivor convertible built mid Dec 65 has the shifter bolted to the transmission also
                  • R N.
                    • May 31, 2002
                    • 640
                    Re: 66 4sp-shifter
                    My AOS '66 trim tag is H16 (March 16th), # 17534 and the M21 is dated P0321 (March 21st) and I'm sure it's transmission mounted.
                    • John C.
                      • May 31, 1993
                      • 72
                      Re: 66 4sp-shifter
                      Thanks everybody on the trans it will beJOHN
