Got a New Toy for My Car - NCRS Discussion Boards
  • Kirk M.
    • June 30, 2006
    • 1036
    Re: Got a New Toy for My Car
    Originally posted by Clem Zahrobsky (45134)
    you can save that $14.99 by buying a new corvette as that display will show up on the dash.
    Dang, wish I had thought of that! Think my wife would fall for that one?
    • Kirk M.
      • June 30, 2006
      • 1036
      Originally posted by Gerard Fuccillo (42179)
      Kirk,
      They really come in handy, I keep mine in all the time, unless it is going to sit for a long time.
      I got mine after I overhauled my alternator, and was cooking my lead acid battery with over-voltage. Used it to adjust the voltage down at the voltage regulator.
      Now that I have one of those restoration gel batteries, it is very important to keep the voltage low in the 14-14.5 range at all rpms. You can ruin one of those expensive gel batteries by charging them over 15 volts.
      Pretty much the same thing happened to me the first summer I drove my car. Melted my battery. Thank goodness when I stopped for gas I was only 0.5 miles from home - shortest flatbed haul the driver had ever done. Worked for me.
      By the way Gerry, wanted to thank you for all your carpet posts regarding cuts and so on. They were extremely helpful in making sure I got mine correct.
      Kirk
      • Clem Z.
        • January 1, 2006
        • 9427
        just trying to be of help.
        • Henry S.
          • April 30, 2005
          • 816
          I remembered this post from last month and finally picked one of them up at Wal-Mart. I decided yesterday to take the 67 up to a buddy to have him buff the car out (fine scratches). I hadn't tried the voltage meter out yet so while I was driving it up to his shop I plugged it into the lighter. Boom, the reading was 15.28. Which I didn't think was right. Just as luck would have it, it started sprinkling so I turned on the wipers so of course the reading dropped a little to 14.68-70. Now I'm wondering, do I have problem with too high voltage? Any suggestion are appreciated. I have a cut-off on the battery that I always unhook when I stop. I won't get the car back until the end of the week so it will be at least then before I can check it out. Suggestions??
          Thanks, Shooter
          P.S. I called a local mechanic and he asked what the reading was with the car shut off but I didn't get a chance to check it yet, the only reading I got was the one with it running.
          • Gerard F.
            • June 30, 2004
            • 3803
            Shooter,
            I think you are OK by the Service Manual, but you may be cooking your lead acid battery in hot weather if it continues to show over 15 volts after the regulator warms up. I had the same high voltage readings and found that I was always adding water to the lead acid battery in hot weather.
            What a mess it made to the battery tray and under the battery. So I turned the voltage down to around 14 to 14.5v when the engine compartment is warm. Easy to do at the voltage regulator, and your new toy makes it even easier.
            If you have a restoration gel battery, as I have now, it is very important you not charge it over 15 v. That could ruin one of these expensive batteries.
            Jerry Fuccillo
            • George C.
              • December 1, 1988
              • 583
              Very nice, perfect. Save the Wave.>George
              • Dale S.
                • November 12, 2007
                • 1224
                Roy, Does it work on 6 volts? Just kidding Dale
                • Henry S.
                  • April 30, 2005
                  • 816
                  Shooter,
                  Jerry, I have one of those gel restoration also so I was concerned about the voltage being that high. That was one of the first things my mechanic buddy mentioned, was the water low in my battery. I'm going to get it looked at as soon as I get it back from the buff and detail job. Kind of feel l ike I'm doing things a**backwards. Car should be running right BEFORE you get it detailed. Thanks for the reply Jerry!!
                  Take care,
                  Shooter
                  • Kirk M.
                    • June 30, 2006
                    • 1036
                    #24
                    Thanks, Shooter
                    Check the voltage regulator??? Might be going south on ya. Seems high according to what people told me at 13.8V.
                    Kirk
                    • Henry S.
                      • April 30, 2005
                      • 816
                      #25
                      Kirk
                      Thanks Kirk, I'll check the regulator out. I got a "correct" refurbished one about a year and half ago but still have the one that came on the car.
                      I wonder, if it's bad can they be rebuilt?
                        • May 31, 1974
                        • 8377
                        #26
                        Originally posted by Roy Braatz (182)
                        Now that is a great idea for checking the system out , I have to get one and use it for my 55.
                        One more accessory
                        roy: if you keep adding accessories to your 55, you'll need more room. Just take the trunk lid off and get one of those pickup beds that were 1939 etc chevy accessories that slides in the trunk. you could then install 6 tail-lites like the midyears were treated to in the '60's and 70's.then hang a couple of racoon tails off the tailgate. have fun. mike
                        • Henry S.
                          • April 30, 2005
                          • 816
                          #27
                          Don't you already have one of those Corvette campers you pull around with all your "accessories" in it Roy.
                          • Roy B.
                            • February 1, 1975
                            • 7044
                            #28
                            I think I've added every GM accessory they made for 1955 and some after market items of the 50's , so dont temp me to add any more.
                            Radiator filter
                            Engine heater
                            Battery heater
                            Look-out-mirrors
                            AC tags
                            Wire wheels
                            Bubble top
                            Hard top
                            Spot light
                            AC automatic cigg lighter
                            Flamless ash tray
                            Oil eye
                            Vacuum
                            Car temperature gage
                            Car clock
                            Dated flares
                            Red road flags
                            Tool kit
                            Headlight holder( Spare)
                            Car shaver
                            Locking gas cap
                            Gas pedal cover
                            Curb feelers
                            Baby bottle warmer
                            Tissue Box
                            And more
                            • Joe R.
                              • May 31, 2006
                              • 1822
                              #29
                              Shooter,
                              The voltage regulator can be restored by John Pirkle. I don't have any experience with having mine done. I will probably try it if mine is original.
                              Joe
                              • Henry S.
                                • April 30, 2005
                                • 816
                                #30
                                Originally posted by Joe Raine (45823)
                                Shooter,
                                Joe
                                Thanks Joe. Hopefully I'll get a chance to look at it this week-end.
