1968 engine stamping - NCRS Discussion Boards
  • Jim B.
    • November 1, 1982
    • 10
    I am rebuilding the motor in my 68 327/350. The car is a 4 sp. with A/C only, no P/S or P/B. I am not the original owner so it's originality is unknown. My question is should the motor be stamped with a HP or HT. The Tech. Manual list both.
    Re: 1968 engine stamping
    Guess I don't see the question/issue...
    The HP suffix code in my book relates to a 327/300 engine with MT, A/C, and PB. The only code for a 327/350 engine is HT regardless of other options.
    • Lou C.
      • August 31, 1992
      • 134
      1968 HP code is for 350 HP, Manual trans, P/S & A/C
        That's a hoot...there's an ERROR in the Corvette Black Book! It says what I recited but that's in conflict with what's listed in the NCRS JG book as well as Hollanders!
        The NCRS JG says:
        HP= 327/350 with MT, P/S and A/C
        HT= 327/350 with MT
        Here's the Black Book table I cited...
        • Tom H.
          • December 1, 1993
          • 3440
          NCRS pocket spec book also lists the HP suffix as base motor 327/300 with MT / AC and PS.
          I assume this is in error and I should make a correction in the book ?
          Tom Hendricks
          Proud Member NCRS #23758
          NCM Founding Member # 1143
          • Tom H.
            • December 1, 1993
            • 3440
            The NCRS JG says:
            HT= 327/350 with MT
            I think you may have an old Black Book. Mine shows the HP suffix as 350HP MT/PS/AC.
            Tom Hendricks
            • Paul B.
              • April 30, 1995
              • 482
              I have two original "HT" 327/350hp 1968 cars. One is a coupe, no A/C, manual steering & manual brakes. Other is a power steering, power brake convertible, also no A/C.
              ...this issue has come up a few good times in my 10yrs on the InterWeb on 1968 Corvettes.
              • Bryan M.
                • April 1, 1999
                • 386
                My '68 build number 4888 327/350hp with ps, pb, 4-speed, with a/c has the HT code stamped on it. Has anybody ever seen a 68 with the HT code in this configuration?
                • Jim T.
                  • March 1, 1993
                  • 5351
                  Jim what does your engine have stamped, HP or HT?
                  My original owner 68 has the 327/350 HT original engine. No a/c, pwr brakes, or pwr steering.
                  Kurt Bunting has a 68 with a/c perhaps he will see the post and tell us what stamping he has.
                  • Jim B.
                    • November 1, 1982
                    • 10
                    Thanks Jim, My motor casting is the 678, the date is right for the block and heads. I asume that the motor has been rebuilt once or? as the block has been decked. You use another gentlemans opinion to your answer, would he have any insight to my problem? Thanks in advance,
                    Jim Benedict
                    • John P.
                      • January 28, 2009
                      • 7
                      The casting # on my 1968 327 ends with "HE" (VO717HE).
                      300 hspwr, 4sp., PS, PB..
                      Best to the Board.
                      John Pratt
                      • James G.
                        • May 31, 1976
                        • 1556
                        I believe "HP" is correct for 327/350hp WITH AC and Power Steering. Same code on 66 and 67 cars also. I had a 66 with 350hp, air conditioning, power steering and K-19 California Smog pump. That engine was "KH"
                        I have seen some "HT" stamps on 327/350 air conditioned cars over the years, but never at a judged NCRS meet.
                        • Bryan M.
                          • April 1, 1999
                          • 386
                          The "HT" engine stamping has always puzzled me about my car. Is it because my car also has power brakes that it kept the "HT" stamp?
                            Bryan -
                            With or without power brakes has no impact on the engine configuration/suffix.
                            • Bryan M.
                              • April 1, 1999
                              • 386
                              Bryan -
                              John,
                              Do you know the reason why a 68 with a/c would have the HT engine stamp?
