Headlight problem - NCRS Discussion Boards
Headlight problem
  • James R.
    • September 30, 2005
    • 93
    Headlight problem
    on my 65, both of my low beams work but when I turn on the high beams, the left side works but on the right side nothing works (low beam also goes out). Any thouhts on what I should check next?
    Jim
  • Rich P.
    • January 11, 2009
    • 1361
    Re: Headlight problem
    Jim,
    both headlights might be bad. The low beam also has a high beam filiment and if its bad the low beam will not work on high. A quick chek is to swap both headlamps and test.
    Rich
    • James R.
      • 93
      Originally posted by Rich Pasqualone (49858)
      Jim,
      Rich
      Rich,
      I did swap out the headlights as my first test and the right side went out regardless of the headlamp.
      Jim
      • Rich P.
        • January 11, 2009
        • 1361
        Jim,
        if it was the dimmer switch then both low beams should go out. I would check to see if I had power/good gounds at the terminals with a test light.
        Rich
        • Rich P.
          • January 11, 2009
          • 1361
          Jim,
          I also wanted to mention that is is very common to have a lose connection at the H/L extension harness.
          Rich
          • Mark W.
            • January 31, 2001
            • 160
            I had a similar problem with my '66 and found a broken wire. After 40+ years the old wiring gets brittle.
