1966 parking light wire clip - NCRS Discussion Boards
  • Todd H.
    Infrequent User
    • November 1, 1999
    • 28
    I need dimension and/or pictures of the wire harness clip for the parking light wires located on the front section of the front wheelwell behind the grill area. Paragon lists a P/N 13076 "J" clip, 1 1/2" long rubber coated, and a P/N 13140 "J" clip, 2" long rubber coated. Are either of these close to being correct?
  • Craig O.
    • July 31, 1983
    • 207
    Re: 1966 parking light wire clip
    are you looking for placement of clip?
    • Todd H.
      Infrequent User
      • November 1, 1999
      • 28
      I have the holes located, but don't have the clips.
      • Todd H.
        Infrequent User
        • November 1, 1999
        • 28
        I am still looking for this information, any help is appreciated.
        • Alan D.
          • January 1, 2005
          • 2049
          Think you are asking about the front wiring harness supports?! The front parking lights have no clips.
          If I'm correct, what you are inquiring about are the clips located on the metal header bar reinforcement (3) and the two right next to where the parking light connects to the harness which use large head rivets on the glass. The first clip, 13076, looks the closest. Now I have a 64, so that's what I'm looking at so you will need a 66 guy to confirm or get the part number off the AIM if there.
          Perhaps if you post as a wiring harness clip.
          • Todd H.
            Infrequent User
            • November 1, 1999
            • 28
            I'm not talking about the header wire clips. I'm talking about the clips attached to the front side of the wheel well, one per side. There is a hole where the parking light wires pass through the wheel well, and a clip located about 2 1/2 inches above and slightly outboard of the hole which is held in place by one aluminum rivet.
            • Mike M.
              Director Region V
              • August 31, 1994
              • 1463
              Hi Tom
              I have just reviewed the aim and still not sure of the location to which you are referring.
              You two may be talking about the same clips. It would seem the clips you are describing are the outboard harness end clips that Alan has described.
              The parking light wires are without other clips, routing through the skirt, between the skirt and bumper bracket to the socket attachment.
              The only other clip I can find on the forward side of the skirt is the clip retaining the passenger side horn wire to the core support.
              Are we still missing something?
              HaND
              • Todd H.
                Infrequent User
                • November 1, 1999
                • 28
                • Todd H.
                  Infrequent User
                  • November 1, 1999
                  • 28
                  Mike, reviewing the 1966 AIM, page F242, the clip is item 4, P/N 3799990. This clip does support the end of the headlight harness, just above the hole in the fender well.
                  • Alan D.
                    • January 1, 2005
                    • 2049
                    OK, same clip, 3799990, used in 64 - thanks for checking and listing number.
                    The photo is of an original Mar64 car. Hope this helps, the 13076 looks close.
                    Sorry its not clear, but should get you headed to right part.
                    • Todd H.
                      Infrequent User
                      • November 1, 1999
                      • 28
                      Thank you, that's what I was looking for.
                      • Mike M.
                        Director Region V
                        • August 31, 1994
                        • 1463
                        Yep, looks like we were all talking about the same clip.
                        Good luck and HaND!
