C2 doors - NCRS Discussion Boards
C2 doors
  • John F.
    • July 31, 2005
    • 11
    C2 doors
    I have a 67 conv driver door that needs repair but before I decide to spend the time replacing the rivets and such. Can someone tell me if all conv C2 doors are the same? I heard the area where the internal door handles attached on the 63's are different but other than that all are the same. I have not been able to verify this. The reason I ask is I may replace the whole door vs repair. Thanks for the help.
  • Chris E.
    • November 3, 2006
    • 1326
    Re: C2 doors
    63 and I believe 64 had raised sections of the exterior fiberglass near the door handles.
    On the insides, the door panels were different throughout 63-7. I think they changed them every year, but double check me on that.
    Chris Enstrom
    2011 Z06, red/red
    • John F.
      • July 31, 2005
      • 11
      Re: C2 doors
      Chris - Thanks for the info. I will keep digging as I have not found a source for this info yet. I will post it when I do find it.
      • Chris E.
        • November 3, 2006
        • 1326
        Re: C2 doors
        Yes, please do.
        Also, I can say that because of the difference between the 63-66 and 67 door panels, that there should be an internal configuration difference. In other words, the lock knob is at the back of the door panel for 63-66, and in the middle for 67.
        Chris Enstrom
        2011 Z06, red/red
        • Mike M.
          • May 31, 1974
          • 8381
          Re: C2 doors
          67 doors differ from the 65 and 66 doors in that the inside door lock mechanism is in a different location on the 67 doors.. also , there were differences in the shape of rivets used in st louis doors vs AO Smith manufactured doors. mike
          • Gene M.
            • April 1, 1985
            • 4232
            Re: C2 doors
            Also AO Smith doors do not fit on St Louis cars. And the reverse is also true. If installed on the wrong car fit will suck.
