How much HP do i have - NCRS Discussion Boards
  • Steven A.
    • March 29, 2009
    • 14
    I have talked with the previous owner of my car. When it was totally body-off restored and the 396 rebuilt; it was fitted with hardened seats and quote, "the compression was lowered from 11:1 to about 9.5:1" in order to run pump gas. Everything else remains factory stock. It is obvious from the way it runs and sounds that it still has a performance cam, solid lifters, etc. Given his statement is accurate; what has that done to my horsepower?
    Steve Allison
    50236
  • Bill B.
    • November 30, 1993
    • 192
    Re: How much HP do i have
    Steven - I have found on Comp Cams website CamQuench 6 its a free 2 minute download you can put in all your engines information and by changing the compression instantly you can see the peak horsepower and peak torque change. Just a suggestion and a good learning tool.
    Good luck,
    Bill
    1961 Black/Silver/Red Int. 283/315 FI
    power windows. Frame off 65% completed.
    1989 hard top daily driver 165,000 miles
    • Bill M.
      • March 31, 1977
      • 1386
      Steve:
      When GM dropped the compression ratio in the LT-1 from 11.0 to 9.0, the gross went from 370 to 330, about 11%. Lets use 3/4 of 11% for 9.5. 425 - 8% = 391.
      • Joe R.
        • May 31, 2006
        • 1822
        Steve,
        Why not run the car on a chassis dyno to see how much rear wheel horsepower (RWHP) you really have? From that you can estimate what the engine hp is. I don't remember the factor offhand, but I've seen it here. I can dig it up if you're interested.
        Joe
        • Joe C.
          • August 31, 1999
          • 4598
          Steve Allison
          50236
          Bill is right. In addition, keep in mind that the old fashioned horsepower numbers, prior to 1972 were inflated (gross). If you want to correlate your pre 1972 engine's horsepower figures to modern standards (ie 638 GM estimate 2009 ZR1), then you would deduct an additional 12 per cent, to end up with 344 net HP. Keep in mind that this number is not fixed, but tied to the point where torque dropoff begins to exceed RPM rise. What it means is that across the board, you should expect an average 11 per cent torque deficit with the lowered SCR.
          • Ken A.
            • July 31, 1986
            • 929
            Steve Allison
            50236
            Never enough!
