What Rear Axle is this? - NCRS Discussion Boards
  • Jack A.
    • February 28, 2001
    • 129
    Hi Guys,
    I have been restoring my 61 Fuelie and finally got around to looking more closely at my Rear Axle. I looked up the numbers and I'm afraid I may have a passenger car Posi unit. The date is correct but the numbers don't line up with the NCRC Judging Book. The number on it is 3789812 with a K230 date. Any ideas? Also on the other side is the designation AL 1212.
    Jack Alexander 35730
  • Bill O.
    • March 31, 2006
    • 542
    Re: What Rear Axle is this?
    Jack:
    You have the correct casting number and the casting date looks like November 23, 1960.....do you have an early '61....maybe December '61 - February '62 final assembly??
    Bill
    • Edward M.
      • October 31, 1985
      • 1916
      My references show AL code as a 4:11 posi, with a 3 speed overdrive, installed in a passenger car. 1212 would be a December 12th assembly date.
      • Bill B.
        • November 30, 1993
        • 192
        Jack - Yes, your numbers are correct and the date as previously stated depends on your production date. The code for 61 for 4.11 should be AP positraction manual transmission, or AT positraction manual trans & H.D. Brakes & Suspension, or FL positraction manual trans & Metallic Brakes.
        My 61 fuelie has 3789812 FL and my build date is November 15, 1960.
        Bill
        1961 Black/Silver/Red Int. 283/315 FI
        power windows. Frame off 65% completed.
        1989 hard top daily driver 165,000 miles
        • Jack A.
          • February 28, 2001
          • 129
          Hi Guys,
          What a relief! Yes my build date is Feb 12, 1961. Sounds like I am OK. I really appreciate the research on my behalf. I appreciate you guys so much. Bill you have helped my before with my 315 HP 61. I'm also about 65% complete. I can't wait. I don't plan to have it judged but I'm going NCRS anyway and having a blast doing all the Sherlock Holmes work on it.
          Jack Alexander (35730)
          • Bill O.
            • March 31, 2006
            • 542
            Jack:
            You are good to go. Have fun and you may just decide one day get it ready for flight judging....just go for it. We only have so many summers left!
            Bill
            • Bill B.
              • November 30, 1993
              • 192
              Originally posted by Jack Alexander (35730)
              Hi Guys,
              Jack - Don't hesitate to contact me anytime. You will probably have yours done long before mine, it's a slow process thats in its 15th year I call it basket case to beauty in under 20 years...ha ha ha...Good luck and Gods speed.
              Bill
              • Edward M.
                • October 31, 1985
                • 1916
                Hi Guys,
                Jack;
                I'm confused (which is my normal state). I believe that the code stamped on your gear assembly (AL) indicates a passenger car 4:11 posi, not a Corvette 4:11 posi.
                • Jack A.
                  • February 28, 2001
                  • 129
                  Hi Bill,
                  You are not confused what you are is misinformed due to my blindness. What I have is an (AP ) not an (AL). Thanks to you I got the pleasure of crawling under "Americas Sportscar" to get a better look. Really I do appreciate the help.
                  Thanks again everyone!!
                  Jack
                  • Edward M.
                    • October 31, 1985
                    • 1916
                    Hi Bill,
                    Jack
                    Congratulation...you are there. Good luck on the car
