Long Thin Vacuum Hose From heater to... - NCRS Discussion Boards
  • Jamie F.
    • May 20, 2008
    • 337
    There is a long thin hose that runs from the top of the heater box through the firewall pn the passenger side and over to the master cylinder area on a 69 non A\C car. I think it is supposed to splice into the yellow striped hose from the vacuum tank. Where abouts should this splice be made?
  • Jamie F.
    • May 20, 2008
    • 337
    Re: Long Thin Vacuum Hose From heater to...
    Also can anyone describe, or have a pic of what this "T" fitting should look like? I assume it has two large ends for the yellow striped hose and one small nipple for the heater vac supply hose?
    • Rich P.
      • January 12, 2009
      • 1361
      Jamie,
      Check out this thread. And 1/2 way the page I posted a picture of an original TEE.
      Rich
      https://www.forums.ncrs.org/showthre...95288&uid=7163
      • Jamie F.
        • May 20, 2008
        • 337
        Thanks Rich, very helpful!
        That's exactly what I thought it would look like.
        Any idea where exactly this tee should be spliced in on a non- A/C car???
        Maybe someone could give me a measurement from the vacuum tank or the Wiper Valve (my valve is up on the Driver side firewall, not over in the fender((late 69)))
        • Jamie F.
          • May 20, 2008
          • 337
          I scoured through the AIM and all I can find is the location of where the heater vacuum supply hose splices in when the wiper valve is mounted in the pass. fender area.
          My car is a later car that has the wiper valve over on the drivers side firewall by the master cylinder and there is no indication in the AIM where that splice should be made?
          Anyone that can take a look at theirs and give me an idea?
          Is it over by the vacuum tank, or close to the wiper valve?
          Thanks in advance!
          • Brian M.
            • February 1, 1997
            • 1839
            Get the diagram from Dr. Rebuild. All of them. JMHO
