Paint removal engine pad - NCRS Discussion Boards
  • Don W.
    • September 30, 1997
    • 492
    What's the best solvent to remove paint from the engine pad; I tried laquer thinner with Q-tips but I think I'll die of old age before the paint comes off.
    Don
  • Michael M.
    • February 1, 1993
    • 606
    Re: Paint removal engine pad
    Don I would have tried laquer thinner first also, but again it is a long process. Small amounts of paint remover may work but be very careful with the surrounding parts. I would first try a heat gun, when you start to see the paint bubble use a non-metallic instrument to remove the paint. You can soak rags with water to protect the area around your work.
    • Brian M.
      • February 1, 1997
      • 1842
      I have applied a liquid paint remover with a foam brush, let is sit for a little while and swipe off the paint.
      • Ken K.
        • May 31, 1999
        • 235
        Any type of paint stripper will work. Use a Q-tip to wipe the stripper on the pad. Let it sit for a few minutes and then wipe it off. It may take a few times of doing this, but the paint will come off. Watch so you don't get any of the paint stripping on other parts!
        • Stuart F.
          • August 31, 1996
          • 4676
          As a next step, either for after paint removal or for those of us running bare for so long, how do you best preserve a bare pad so it remains clean of rust, etc.? After they weather a while, it gets hard to read them.
          Stu Fox
          • Pat M.
            • April 1, 2006
            • 1582
            As a next step, either for after paint removal or for those of us running bare for so long, how do you best preserve a bare pad so it remains clean of rust, etc.? After they weather a while, it gets hard to read them. Stu Fox
            From time to time I smear a LITTLE clean motor oil on my bare pad. It lasts a long time, is very resistant to rusting, and can be easily wiped off for judging.
            • R N.
              • May 31, 2002
              • 640
              I use Boeshield T-9 spray protectant
              www.boeshieldcanada.com/info.pdf
                • 15632
                Painters will have a fit, but I put silicone grease on my pad.
                • Mike M.
                  • May 31, 1974
                  • 8408
                  Dixie Pomade works better. it'll slick yer curly hair down well too.mike
                  • Don Y.
                    • July 31, 2000
                    • 166
                    Acetone, incredible paint remover
