1971 Stamp Pad Question - NCRS Discussion Boards
  • Michael P.
    • April 30, 2003
    • 2
    Looking at a 1971 big block with a strange stamping.
    It is C119116*** T0423CPJ
    The "9" should be an "S"
    Everything else seems OK.
    Is this likely to be a factory error?
  • William C.
    • May 31, 1975
    • 6037
    Re: 1971 Stamp Pad Question
    Look at the transmission stamp, they should be identical, stamped by the same person using the same tool.
    Bill Clupper #618
    • Michael P.
      • April 30, 2003
      • 2
      Good idea Bill. Will see if the tranny is original.
      • Tom L.
        • October 17, 2006
        • 1439
        Off topic, but are stampings on blocks and transmisions done by one person by hand or using some type of jig? I've read threads that talk about irregular stampings and I wondered if that's why. Thanks!
        • William C.
          • May 31, 1975
          • 6037
          If you mean are they stamped by a person with a (large) hammer, yes, but at least in the later years, the numbers were in a gang holder so all the VIN characters were stamped at once. The engine plant process was a little different and there are a lot of discussions on that in the archives.
          Bill Clupper #618
