1957 Frame - NCRS Discussion Boards
1957 Frame
  • Dan P.
    • December 1, 1990
    • 683
    1957 Frame
    Were the frames the same from 57 -62. Can a 61-62 be made NCRS correct for A 1957 .
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 1957 Frame
    Basically yes ! Money can can do it.
    • Dan P.
      • December 1, 1990
      • 683
      Re: 1957 Frame
      thanks for the reply
      • Tom P.
        • April 1, 1980
        • 1826
        Re: 1957 Frame
        Dan,
        The fundamental difference in later frames is brackets which were added in 59 and 60-62.
        Also, later frames have additional holes in the rear cross member for attachment of bumper braces.
        The 59-62 cars had radius rods added (factory traction bars) above the rear axle housing which were attached to a welded-on bracked to the fame rail forward of the axle housing. Then, in 60, a rear sway bar was added and another bracket was welded to the frame rail on the inside of the frame and aft of the axle housing.
        Using a die grinder and a cutoff wheel, these brackets could be removed by VERY carefully cutting through the welds then VERY carefully grinding down the remnants of the welds on the frame.
        This could be done, BUT, on my 56, I chose to UPGRADE the chassis to that of a 60-62 by adding the brackets, radius rods and rear sway bar!
        • Dan P.
          • December 1, 1990
          • 683
          Re: 1957 Frame
          Thanks that is just what i was tol to do .
          • Tom P.
            • April 1, 1980
            • 1826
            Re: 1957 Frame
            Dan,
            If you cut those brackets off, and don't want to keep them, and they're in good shape, I'd sure be interested in them!!!
            • Jim H.
              • April 1, 2002
              • 112
              Re: 1957 Frame
              Dan,
              61/62 frames have different exhaust mounting points. You need the brackets for the rear area of the exhaust welded to the frame rails.
              • Edward M.
                • November 1, 1985
                • 1922
                Re: 1957 Frame
                And the front frame horns are different. The 58 and up frames have a flat surface on the outside edges where the bumper brackets mount to. The 56 and 57 (and earlier, I think) have a sort of "double humped" surface.
                This is one case where a picture would really come in handy. Unfortunately, I don't have one.
                • Ed M.
                  • August 31, 1996
                  • 52
                  Re: 1957 Frame
                  Dan, I replaced my original '57 frame and the old one is in Osawattomie, KS.. about 45 minutes South of Shawnee... not perfect but original... if you want to see it let me know... Ed
                  PS... your shocks are working out well...
