C2 Rear Spring Help - NCRS Discussion Boards
C2 Rear Spring Help
  • Mark P.
    • May 13, 2008
    • 951
    C2 Rear Spring Help
    I got this spring as one of the spare parts when I got my 1965.
    Does this look like a NOS F40 spring or a repro ? A friend said it kind of looked like his F40 spring but should not have the plate on the bottom of the 7th leaf.
  • Mike M.
    • May 31, 1974
    • 8409
    Re: C2 Rear Spring Help
    show a close-up of the ends of all the spring leafs.mike
    • Mark P.
      • May 13, 2008
      • 951
      Does this help ?
      • Mark P.
        • May 13, 2008
        • 951
        One more photo....
        • Mike M.
          • May 31, 1974
          • 8409
          flaring of the ends of all the secondary leafs is common to original c-2 and i believe c-3 springs . i've not seen any aftermarket leafs with the flaring feature so i'd say you have original vette spring. mike
          • Gary B.
            • February 1, 1997
            • 7080
            C2 Rear Spring; My guess is repro
            Mark,
            From 1975 thru 1979 the HD spring came with a flat top plate like on your spring. Can you measure the thickness of the top plate? For 1975-1977 it should be 0.306". For 1978-1979 it should be 0.225".
            The stenciled number on the spring is not a GM part number. My guess is the number is the code from the Spring Research Institute and this would suggest the spring is a repro. Also, are the angle cuts on the ends of the main leaf at 45 degrees? If not, that would also suggest it's a repro.
            Having said that, the end treatment on leaves 2 thru 7 looks very close to the GM style.
            Gary
            • Mark P.
              • May 13, 2008
              • 951
              Hello Gary. Its .295 so this looks like a 75-77 spring, right ? The ends are at 45 degrees. Could it be NOS ?
              • Gary B.
                • February 1, 1997
                • 7080
                Mark,
                NOS? Don't know for certain, but the non-GM number suggests otherwise.
                Gary
                • Bill M.
                  • April 1, 1977
                  • 1386
                  This looks identical to the 7-leaf 370350 I bought from Chevy in 1979. Mine has the thicker plate. (I painted the spring in 1979; don't remember if there was a part. no. on it.)
                    • 11698
                    Re: C2 Rear Spring; My guess is repro
                    Originally posted by Gary Beaupre (28818)
                    Mark,
                    Gary
                    I would agree with your comment regarding the ends of the bottom leaf not appearing to be cut at 45 degrees from centerline.
                    I would also note that the liners do not appear to be the typical "H" shape that came on GM springs. These do not appear to have any "end" to the "H" - just a flat piece of plastic.
                    Patrick
                      Mark -
                      Is there a remnant of a stenciled "JRS" on it anywhere? John R. Spring Service in Warren, Michigan has been the primary manufacturer of the reproduction 7-leaf HD spring for many years.
                      • Gary B.
                        • February 1, 1997
                        • 7080
                        NOS? Sort of...
                        Mark,
                        My guess is your spring is an NOS spring. I just don't think it's a GM NOS spring. Having said that, the ends look to be the correct tapered rolled style, so the spring would be close to the value of a GM NOS spring, which is to say, of significant value to someone who knows his or her spring geometry. My guess is the spring is an old NOS spring, made by someone back in the 70's who knew how to do it right, such as JR Spring, as John mentioned. The current repro springs are not very close in terms of the end treatment on leaves 2 thru 7.
                        Gary
                        • Mark P.
                          • May 13, 2008
                          • 951
                          The leafs are all 2 1/4" wide.
                          Here are the lengths for the leafs.
                          49", 42", 36", 30", 23", 17", 11" and the piece that bolts on the bottom is 7".
                          Does this make it any clearer what this spring was for ?
                          • Gary B.
                            • February 1, 1997
                            • 7080
                            Leaf width
                            I think 2.25" wide applies to 63-77, after which the width increased to 2.50".
                            Gary
                              Re: Leaf width
                              Gary
                              Yup, you're correct - fat-finger typo on my part; deleted my previous post.
