C-2 1967 Headlight rotation switch - NCRS Discussion Boards
  • Dale S.
    • November 12, 2007
    • 1224
    Does anyone have a close up picture of the headlight rotation switch and the screws that mount it? Thank you Dale
  • Gene M.
    • April 1, 1985
    • 4233
    Re: C-2 1967 Headlight rotation switch
    pan head phillips head black oxide finish #10-24 screws
    • William L.
      • December 1, 1988
      • 944
      Here ya go Dale.
      Bill Lacy
      1998 Indy Pacecar
      • Dale S.
        • November 12, 2007
        • 1224
        Thank you, What is to the left of the rotation switch? The screws look the same as mine. I sent you an email. Dale
        • William L.
          • December 1, 1988
          • 944
          Dale will this picture help. Bill
          Bill Lacy
          1998 Indy Pacecar
          • Alan D.
            • January 1, 2005
            • 2055
            Dale,
            Double check your 67 AIM for the correct position of screws. Non AC cars have ears of switch showing while AC cars do not as the picture shows.
            Know that is how the 64AIM is, however 67 may all be the same? Know the judges look for this orientation.
              Nope. The switch ears are correct as shown in Bill's photos, hidden above the lower flange of the cluster; look closely at the Assembly Manual illustrations in UPC 12 for all '63-'67's and follow the lines from the attaching screws carefully - they go through the cluster first, then through the ears, then into the speed nuts.
              • Dale S.
                • November 12, 2007
                • 1224
                Thank you to All. Dale
