1967 Vette Parking Brake - NCRS Discussion Boards
  • Michael V.
    • April 16, 2009
    • 9
    The button & spring in the handle of the parking brake popped out. Can it be reinstall or do you need to replace the entire parking brake handle unit???
    Re: 1967 Vette Parking Brake
    Michael -
    Member Jeff Salz restores them, and he'll have the answer; if he doesn't spot your post, you can contact him through his profile in the member list item near the top of the page.
    • Stephen L.
      • May 31, 1984
      • 3162
      That happened to mine also. I just reinstalled the spring and put the button back on the shaft using a small amont of CRAZY GLUE. That was 3 yrs ago and it still together.
      • Michael V.
        • April 16, 2009
        • 9
        Thank you for the help..........
        • Michael V.
          • April 16, 2009
          • 9
          Thanks for the info
          • Michael V.
            • April 16, 2009
            • 9
            If you glue the button & spring, does the button still work so that when you rise the handle the parking brake holds?
            • Gerard F.
              • June 30, 2004
              • 3806
              MIchael,
              I used a silicone glue on my parking brake button. You have to tape the button closed until the glue takes a set, or the spring will just pop the button out.
              Jerry Fuccillo
              • Wayne W.
                • April 30, 1982
                • 3605
                Line from The Blues Brothers. " Epoxy, good stuff."
                • Ralph P.
                  • October 7, 2008
                  • 3
                  I just received my 67 handle back from Jeff Salz on Friday. A true work of art. Do yourself a favor and spend the $200 and it will be better than new. His email is jeffstuarts@aol.com Good luck
                  • Michael V.
                    • April 16, 2009
                    • 9
                    Thanks for the info...I'll follow up with Jeff..
