I saw a very detailed post on this from last summer. I'm still confused.
The distributor has a newly installed B26 vacuum advance. This was installed when the previous owner took the distributor into be recurved 3 months ago.
Should I swap this for a B20 vacuum advance instead ? This tuning site mentions that the B26 and B20 are the same and have part number VC1765. Duke Williams is referenced in the article.
http://www.lbfun.com/warehouse/tech_...ance_Specs.pdf
Are the specs of 0 at 6lbs and 24 at 13 lbs what I should target ?
The 1111076 distributor has a date of 8/24/64 (4 H 24). This is 5 months and 11 days before my VIN assembly date. Could this distributor be original ? Would it pass judging ?
