67 Cluster Odometer Clip Question - NCRS Discussion Boards
+ More Options
Posts
  • Howard P.
    • May 20, 2008
    • 67
    I am just concluding a refresh of my cluster and although I thought I had photographed every possible component at dis assembly I find myself left with one component which I can't remember where it installs exactly.
    I believe it installs on the Trip Odometer. It is a very small "l" shaped clip with centre slot. It is approx 1/4" in length.
    Does anyone by chance have a picture showing correct placement for this piece ? Appreciate any and all comments.
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 67 Cluster Odometer Clip Question
    Originally posted by Howard Poulter (49046)
    ....I believe it installs on the Trip Odometer. It is a very small "l" shaped clip with centre slot. It is approx 1/4" in length. Does anyone by chance have a picture showing correct placement for this piece ? ....
    Howard -- this might help; exploded view of type "W" speedo heads, which includes 1967 Corvette, from a 1967 AC Delco service manual. Looks like you're describing the two retainer clips that hold the drum with the figures.
    Quality of these pics may not be the best. I have a CD of the AC Delco service manual for all GM, but for some reason, was unable to print this [.pdf] page; so I took a pic directly off the monitor .
    • Howard P.
      • May 20, 2008
      • 67
      Wayne
      Thanks very much for your help it appears to be correct though the ones in your pic are straight and mine has a bend on the end and I only have one pc !
      Howie
