68 Seat Belts - NCRS Discussion Boards
68 Seat Belts
  • Jeffrey A.
    • October 22, 2006
    • 273
    68 Seat Belts
    I am now into restoring my interior of the 68 coupe and when I purchased the vehicle no seats or associated componente relating were with the car, so I am starting from ground zero in the seat belt department. I have purchased from America finest my seat belts for my 63 but I was not totally excited with them, the buckles were fine but the straps were just OK the webbing was correct but over all for the money they were OK. Has anyone every dealt with Snake Oyl Products? Any advise is welcomed on where to turn to or whom to call - Thanks Jeff
  • Henry J.
    • November 1, 1999
    • 457
    Re: 68 Seat Belts
    Jeffrey:
    Snake Oyl Products did the belts on my 68. I am satisfied with their work.
    I have read many complimentary posts on this board regarding Seat Belt City. See their ads in the Driveline for contact information.
    Good luck.
    Henry
    • Jeffrey A.
      • October 22, 2006
      • 273
      Re: 68 Seat Belts
      Thanks Henry I appreciate your time on this it is very helpful. - Jeff
      • Edward S.
        • December 1, 1986
        • 514
        Re: 68 Seat Belts
        Charlie at Seat Belt City does a great job and his turn around time has always been good.
        • Pat K.
          • November 1, 2003
          • 351
          Re: 68 Seat Belts
          Jeff - I used Charlie Santorelli at Seatbelt Sity for my '69 and was very satisfied. The number I have on file is 908-719-2354.
          Pat
          • Jeffrey A.
            • October 22, 2006
            • 273
            Re: 68 Seat Belts
            Pat and Ed.
            Thanks for the heads-up. I will give charlie a call this week. Thank for the advise. Jeff
            • Tom H.
              • December 1, 1993
              • 3440
              Re: 68 Seat Belts
              Pat
              He did the belts for my 63 too. Very, very satisfied. As I tell everybody.......... Charlie is not a warm and fuzzy chit chatty kind of guy, but he does great work.
              Tom Hendricks
              Proud Member NCRS #23758
              NCM Founding Member # 1143
              • Gene M.
                • April 1, 1985
                • 4233
                Re: 68 Seat Belts
                Jeff,
                Most of the repop webbing is not correct color or material and thickness. I would suggest you request a sample of webbing material for thickness, color and type of material (nylon vs nylon polyester blend) prior to placing any order.
                • Jeffrey A.
                  • October 22, 2006
                  • 273
                  Re: 68 Seat Belts
                  Gene
                  Thanks for input, As I know from my 63 the webbing was fine, but the thickness was not correct (To Soft) and I do not want to go thru was I did with my 63 for the 68. I called a couple of supplier for samples to check out today. Thanks.
