71 AIR add-on water pump pulley - NCRS Discussion Boards
  • Mike E.
    • February 28, 1975
    • 5141
    Anyone know a source for the add-on water pump pulley for a 71 LT-1? I've checked all the catalogs I have.
  • Robert S.
    • December 11, 2008
    • 122
    Re: 71 AIR add-on water pump pulley
    There are normally several on eBay, but other sources as well. Should be easy to find. By the way, the pully part number for the LT-1 is 3917234.
    • Robert S.
      • December 11, 2008
      • 122
      Correction: water pump pulley is 3991425.
      3917234 is the A.I.R. pump pulley.
      • Michael M.
        • February 15, 2007
        • 455
        Try America's Finest Corvettes in California. That's where I found my AIR pump pulley for my '68.
        • Roy V.
          • April 8, 2008
          • 311
          on page 37 of Doc Rebuild catalog, volume 32, there is a listing for a 71-75 auxillary front single pulley, Part #1063138 and it lists for $65.00.
          Regards
          Roy
          1972 LT-1 Elkhart Green Coupe
          • Mike E.
            • February 28, 1975
            • 5141
            "should be"or "is"? I'm very familiar with ebay, and haven't readily found one, that's why I'm asking if there is another source.
            Roy, thanks for the input. I'll follow that up immediately.
            • Robert S.
              • December 11, 2008
              • 122
              Mike,
              I just looked. There are 2 right now on eBay.
                • 43281
                Mike-----
                There were actually 2 pullies that are functional for the application. The original AIR driver pulley for 1971-78 small blocks with AIR was GM #3991425. For 1979 a new pulley was used, GM #14023158, and shortly thereafter it became SERVICE for 71-78. The latter pulley is very similar to the original except for, of course, "numbers".
                Both of the above-referenced pullies are reproduced by Paul "Goat Hill" Baker.
                • Kenny C.
                  • March 2, 2009
                  • 191
                  Would these numbers also be correct for a 1969 L46 without a/c
                  • Ridge K.
                    • May 31, 2006
                    • 1018
                    Mike, I found three used, originals on ePay.
                    Auction numbers: 320319848796 (24.99)
                    350174203241 (34.95)
                    270304630949 (27.99)
                    and a 4th one that appears to be a repo for $55.00
                    Hope this helps. Good luck, Ridge.
                      • 43281
                      Kenny-----
                      As far as the add-on waterpump pulley, the answer is no. 1969 used a pulley with a 5/8" pilot and 1-3/4" bolt circle; 1971 used a pulley with a 3/4" pilot and 2-1/8" bolt circle. The 1969 add-on pulley was GM #3883235.
                      As far as the AIR pump pulley, they were different for 1971 LT-1 versus 1969 L-46. The 1971 LT-1 used GM #3917234; the 1969 L-46 used GM #3932458.
                      • Kenny C.
                        • March 2, 2009
                        • 191
                        Joe
                        Thank you for the information now I can start looking for the correct parts without wasting time and money on the wrong ones.
