Re: Fire extinguishers: Halon vs DuPont FE36
First let me say, I cannot comment on Halotron, or FE36, as I have no first hand experience with either.
Now back to Halon:
Halon 1301 is the superior type, that is completely in a gaseous form. Every single automatic discharge system I have ever seen protecting everything from airline owned jet aircraft, to an advanced computer system costing hundreds of millions of dollars (American Airlines Sabre), is protected by Halon 1301.
But in your shop of garage, I recommend a co2 extinguisher. I have mentioned before, that one can commonly find used co2 extinguishers for sale at local businesses that service fire extinguishers. Check your local telephone book yellow pages. Store this extinguisher between you, and where you might imagine a garage fire could start up. Another words, keep it close to the door you will be entering the garage with, not stuck in the back corner of the garage or shop.
A third choice for the garage or shop, would be a pressurized water extinguisher. This is the roughly three foot high type, that are commonly seen inside school buildings. Once again, these can be purchased used from extinguisher service companies who have taken them in on trades. You should be able to buy a moderate sized co2, or pressurized water for $25 to $50 tops, in good used condition. (in order to store pressurized water, the shop or garage must be heated, or in a non-freezing climate).
Now back to Halon:
