Clear coat for fuel tank? - NCRS Discussion Boards
  • Henry S.
    • April 30, 2005
    • 816
    I have my fuel tank getting stripped after the previous owner sprayed it with some cheapo galvanize paint. I'm thinking of having it powdercoated matte clear. Has anyone had any experience with powdercoating a tank or is there something better to put on it to keep it looking natural? There was a post in the archives about a clear coat by POR15. Any experience with it? Thanks
    • 11668
    Re: Clear coat for fuel tank?
    Henry,
    I assume you mean your 67?
    Based on my experience with at least 3 of them, I would have just purchased a new tank. I've found it not worth the time and effort to rehab old tanks when compared to installing a new one. Paints used to "spruce up" an old tank will wear and may be affected by gasoline. Unless yours looks like new after you have it stripped (I assume chemically?) I'd consider it a lesson learned and just call Quanta for a new one.
    Patrick
      • 43247
      Henry,
      Patrick
      Patrick and Henry-----
      Yup.
      • Henry S.
        • April 30, 2005
        • 816
        Henry,
        Patrick
        Patrick,
        Yes, I was talking about the 67. The tank I am working on doesn't seem that bad except for the galvanize paint. And thankfully I don't think the guy that painted it knew what he was doing because it is coming off fairly easy. I think it may actually be a replacement already. It does have the correct label/stamping on the bottom. Are the ones from Quantra painted? Thanks for the suggestion. Henry
          • 43247
          Originally posted by Henry Shoot (43807)
          Patrick,
          Henry-----
          Original tanks, Quanta reproductions, NOS GM tanks, and other replacement tanks are terne-coated steel. NONE were painted. The terne coating cannot be re-applied as far as I am aware.
          • Henry S.
            • April 30, 2005
            • 816
            Henry-----
            Joe, Thanks for the information. I went to their web site (and may have missed it) but couldn't find how they were coated. I'll call them tomorrow.
            Henry
            • Chris E.
              • November 3, 2006
              • 1335
              Is there anything that should be done to a NEW tank to help preserve it long term? (30+ years) I'm not going to ever drive the car in the snow, and it'll probably not see much rain either.
              Is there anything I need to spray inside the tank or on the outside?
              Chris Enstrom
              2011 Z06, red/red
              • Larry M.
                • January 1, 1992
                • 2701
                Henry
                Terne coating is a lead and tin alloy coating to preserve steel and prevent rusting. Similar to galvanizing which uses zinc. Google "terne" for more info that you need/want to read. According to internet sources, a Terne2 is now generally used which contains tin and zinc, eliminating the lead hazard.
                Larry
                • Henry S.
                  • April 30, 2005
                  • 816
                  Larry
                  Thanks Larry, I'll check it out.
                  • Michael W.
                    • April 1, 1997
                    • 4290
                    Yes, leave it alone. Salt and condensation/water is what eats the coating, not time.
                    Fill the gas tank during periods of storage and leave it and the car alone.
                      • 11668
                      You should be fine.
                      Keeping it out of humid storage as well as any salt will help.
                      Patrick
                      • Chris E.
                        • November 3, 2006
                        • 1335
                        Thanks guys. Much appreciated. I didn't think there was anything I needed to do (other than storing the car as best I can), but it's good to hear.
                        Chris Enstrom
                        2011 Z06, red/red
