1970 Radio Speakers - NCRS Discussion Boards
1970 Radio Speakers
  • Les G.
    • December 5, 2008
    • 158
    1970 Radio Speakers
    I have installed the original factory radio back in my 1970 convertable only to find the front speakers are bad. I have called around the different aftermarket suppliers to find 8-10 ohm speakers nobody has them they are all 4 ohm. I am afraid to put them in because i don't want to damage the radio. Does anyone know where I can get 8-10 speakers? I believe they are 4X6.
    • 11678
    Re: 1970 Radio Speakers
    Les,
    Pull the front speakers out, and have them "reconed." This is an inexpensive service which will give you your original 10 ohm speakers to reinstall and keep your radio happy.
    One vendor is here:
    Patrick
    • Doug J.
      • April 1, 2005
      • 140
      Les,
      Zip has them, they are part # I-896 they are a 4" x 6" factory speaker for a 10 ohm system. www.zip-corvette.com
        • 11678
        Originally posted by Doug Jorgensen (43687)
        Les,
        Doug,
        I'm "relatively" sure these are the replacements which are still serviced by GM. The connector differs from the originals, for those who care, but they will work just fine if you don't mind modifying the new connector to mate with your factory wiring harness.
        Patrick
          • 3416
          Hi Les,
          You may want to give member Jerry Rudbeck a call. He's been pretty helpful to me in getting my 71 AM/FM radio and speakers working as they should.
          864-363-0947, South Carolina
