67 wiring issue - NCRS Discussion Boards
67 wiring issue
  • Jeremy H.
    • January 1, 1999
    • 260
    67 wiring issue
    I am just finishing a frame off, new wiring and everything. I keep blowing the 20 amp fuse. The bottom one on the panel. What all does it control? It says Clk, ctsy, haz, ltr. I assume that is clock, lighter, courtsey lights and hazards. Anything else? My clock works even with the fuse out. I don't have courtesy lights, lighter and I am not sure about the hazards. Any ideas?
    Jeremy Hedges
  • Ray G.
    • May 31, 1986
    • 1189
    Re: 67 wiring issue
    Hello Jeremy;
    Most common situation w/ lighter etc; fuse blowing is the lighter receiver.
    Have seen many incorrectly assembled lighter bases.
    Look for center receptor prongs to be wrong or not insulated.
    Hope this helps.
    Ray
    I hope you dance
      Re: 67 wiring issue
      Jeremy Hedges
      Jeremy -
      That fuse also feeds the glove box light. If the clock works without that fuse in place, someone has messed with the wiring.
      • Jeremy H.
        • January 1, 1999
        • 260
        Re: 67 wiring issue
        It is brand new wiring that I installed. I have unplugged the lighter and still it blows, I will try and disconect the glove box next.
        • Ray G.
          • May 31, 1986
          • 1189
          Re: 67 wiring issue
          Hello Jeremy;
          Follow the wiring diagram in the manual or;
          A couple of optional ways to proceed;
          Unplug everything and then start reconnecting each item. Include the gauges, directional switch, and ignition switch.
          Also you can try connecting a variable load directional flasher across the the fuse contacts to save fuses. It will disconnect when the draw or short is happening and then obviously reconnect, etc. This method can be called "smoking it out".
          Another wire that pops into the mind is the dark brown ground wire that plugs onto the ground spade at the top of the dash cluster. Make sure it's not plugged into something incorrectly.
          Hope this helps.
          Ray
          I hope you dance
            Re: 67 wiring issue
            Hope this helps.
            Ray
            Ray -
            That dark brown wire connects to the radio capacitor mounted adjacent to the ignition switch, and is "hot" any time the key is in "on" or "accessory". The cluster ground wire that plugs to the spade above the tachometer is black.
            If the brown wire is connected to the ground spade, it makes the entire cluster "hot", and it will then ground through the hood release or the oil pressure line, either of which will become red-hot when the key is turned.
            • Ray G.
              • May 31, 1986
              • 1189
              Re: 67 wiring issue
              Hello John and Jeremy;
              Sounds like your correct. Have not looked recently.
              Sorry Jeremy.
              Hope all is well and tracing according to wiring diagrams never fails, just takes longer.
              Ray
              I hope you dance
              • Joe R.
                • May 31, 2006
                • 1822
                Re: 67 wiring issue
                Jeremy,
                I would recommend the following troubleshooting procedure:
                1. Disconnect the battery. The battery will confuse the ohmmeter used below.
                2. Remove the offending (offensive?) fuse.
                3. Check to see how much lead resistance you have by shorting the + and - leads of the meter. It will make a big difference when you're looking at resistances this small.
                4. Connect an ohmmeter between the load side of the fuse holder and ground. The load side of the fuse should ring (be nearly 0 Ohms) to the cigarette lighter, etc. Subtract the lead resistance mentally when taking all readings. So if the lead resistance is 0.1 Ohms and the meter is reading 0.7 Ohms, the resistance you are trying to measure is actually 0.6 Ohms.
                5. Remove loads (cigarette lighter, lamps, etc.) from the circuit one at a time until the resistance seen is a reasonable value. It should be above 0.6 Ohms (12 V / 20 A). Otherwise the fuse will blow as soon as you try the magic smoke test again.
                I don't like to troubleshoot using the fuse as an indication that the circuit is faulty. The wiring is stressed every time the fuse blows.
                Joe
                • Doug F.
                  • November 1, 1983
                  • 322
                  Re: 67 wiring issue
                  make sure you have double contact bulbs in the courtesy light housings, there are 3 of them,
