Valve Cover Label - NCRS Discussion Boards
Valve Cover Label
  • Alger R.
    • September 30, 1999
    • 279
    Valve Cover Label
    Can anyone post a pic of the 1975 Valve Covel Label that is on the back of the Valve Cover
    AL
    75 Convertible
    L48 M20
    Bright Green / Saddle
    • 15621
    Re: Valve Cover Label
    I don't know wht this one is from, but it has the numbers 75 on it.
    • Jim S.
      • August 31, 2001
      • 730
      CHB was 1975, L48, 350, 165 hp, automatic
      Jim
        • 15621
        Well, looks like Alger might have gotten lucky -- unless he has another engine.
        • Alger R.
          • 279
          This is Perfect! My car is a 4 spd so the suffix code will be CHA (Also appears on the engine pad)
          The Judging manual says that the label is normally on the rear of the pass. valve cover but occasionally on the front.
          It says the label should be yellow but this picture appears to be either white or a very faded yellow. I guess I would opt for an off white or beighe color unless I see one with a brighter yellow
          Thanks, AL
          AL
          75 Convertible
          L48 M20
