56 Water Pump Heater Hose Nipple - NCRS Discussion Boards
  • Mark P.
    • July 31, 2003
    • 407
    I am putting my 56 motor back together and need to know the positioning on the water pump nipple for the heater hose outlet. Is the "slightly bent" nipple angled out away from the block or upward toward the top of the engine? I would think I would angle it outward, but am not sure.
    Also, is it installed with any pipe sealing substance and then painted partially down near the pump or is it installed after painting?
    I appreciate the info.
    Thanks, Mark
    Mark Pugmire
    54 Pennant Blue
    56 Cascade Green Dual Quad
    56 Arctic Blue Dual Quad
    66 Nassau Blue 427 L36 Convertible
    67 Marlboro Maroon L79 Coupe
  • Gary C.
    Administrator
    • October 1, 1982
    • 17773
    Re: 56 Water Pump Heater Hose Nipple
    Mark, most are bent forward towards the radiator. Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Mike M.
      Director Region V
      • August 31, 1994
      • 1463
      Hi Mark,
      Question 2; No sealant (or Teflon tape) was used and I believe it was installed after engine painting.
      HaND
      • Mark P.
        • July 31, 2003
        • 407
        Perfect. I appreciate the responses, Gary and Mike.
        Thanks, Mark
        Mark Pugmire
        54 Pennant Blue
