Gas Line - some questions - NCRS Discussion Boards
  • Oliver S.
    • December 1, 1999
    • 343
    Hello,
    I have to postpone my seasons opening here in Germany.
    I wanted to change my fuel filter on my '65 300hp. Unfortunately the brass female fittings mounted on the filter directly didn't come loose easily. I had to apply some force. After removing them I discovered that the fittings are bent at the orifice of the inlet thread.
    Now I want to order them and have some questions:
    I don't know a source for the fittings to order without the fuel lines here in/from Germany.
    Corvette America offers Fuel lines from pump to carb made of tinned bundy weld steel. Firstly, TBW is the original style, isn't it?
    Does anybody know if the brass fittings to be mounted on the fuel filter and carb directly come also with the lines?
    These fittings seem to require cautious handling when (de)installing in order to avoid bending. Is there a trick when they're very tightly mounted?
    Regards
    Oliver
  • Oliver S.
    • December 1, 1999
    • 343
    Re: Gas Line - some questions
    Oh, I missed to specify the model year.
    Can anybody provide me with the exact specification/name/thread of these fittings for my 300hp Carter AFB? May be there's a chance here in Germany to get them - in a tractor shop.
    Regards
    Oliver
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11364
      Oliver, Zip Corvette has the complete kit including the brass fittings for the filter. I believe TBW was OEM as they say.
      See below:
      The page you were looking for was not found or has been deleted. Search Corvette Parts by year or category instead.
      Rich
      • Mike M.
        • May 31, 1974
        • 8408
        Long Island Corvettes has them and an excellent illustrated catalog from which to select. mike
