Pumpkin Problem - need help! - NCRS Discussion Boards
  • Keith R.
    • August 31, 2001
    • 675
    I'm breaking down the rear axle assembly on my 60 in preparation for rebuilding the chassis and tried to pull the brake backing plates for cleanup only to discover that they won't come off with the rear axles in place. So, I decided to pull the axles out and the ST-12 Service Manual (page 4-7) says to pull the differential cover and then remove the C washers from the inner ends of the axle shafts to allow the axles to be removed. Ok, so I unbolt the differential housing cover (Positraction) and free the cover from the banjo housing but it won't pull clear of the housing. It's loose but feels like it's hung up on something inside. The ST-12 instructions for 1960 refer to the 1953-1955 section which describes a rear cover differential. I don't want to force the cover to avoid causing damage. A fellow chapter member says that the ST-12 instructions are wrong and that I need to snug the cover back down and pull the axles first using a slide puller - no C washers to remove. Any guidance out there?
    Keith MacRae
    NCRS #36692
    New Mexico Chapter
    1960 290HP FI
    2013 427 Convertible
    Shade tree mechanic and
    B-52 pilot extraordinaire
  • Bruce B.
    • May 31, 1996
    • 2930
    Re: Pumpkin Problem - need help!
    To pull the pumpkin from a 60 all you need to do is pull the axles and remove the pumpkin. There are no c-clips or anything else that has to be removed.
    This is the normal sequence to remove the pumpkin;
    Remove tires and brake drums.
    Remove drain plug on housing it there is one.
    Remove the 4 bolts holding the axle retainer to the backing plate and housing.
    Pull the axles and loosen the pumpkin and let lube drain if there was no plug.
    Remove the pumpkin.
    That should be it.
    • Ted S.
      • January 1, 1998
      • 747
      Keith, If you're just trying to get the brake backing plates off you don't need to remove the center section. All you do is unbolt the wheel cylinders and remove the 4 bolts that hold the retainer and the backing plate to the housing. Then pull on the axle. Some have built a slide hammer out of an old axle to help pull the axle as there is a little resistance due to the o-ring seals. There is no rear cover nor C clip on C1 rear ends.
      • Mike M.
        • May 31, 1974
        • 8408
        as keith mentioned, there were no covers on the banjo of a 56 thru 62 vette so if you've got a cover, then you may well have to remove c-clips to pull the axles from a non-56-62 rear end.mike
        • Keith R.
          • August 31, 2001
          • 675
          Thanks Bruce, Ted and Mike. I don't have a rear inspection cover as Mike said - just the front pumpkin that the pinon shaft passes through. So, based upon the advice I've seen so far, I'm going to unbolt the four bolts passing through each of the brake flanges, hook a slide axle puller to the flanges and hopefully the axles will slide out without having to get inside the differential to remove anything.
          Keith MacRae
          NCRS #36692
          New Mexico Chapter
          1960 290HP FI
          • Mike M.
            • May 31, 1974
            • 8408
            the axles are definitly removable without getting into the pumpkin if its a 56-62. if ya don't have a slide hammer, secure both ends of a 10' long piece of logging chain to two of the lug studs, having slid an end of the chain thru a 6" or 8" concrete block.then "throw" the concrete block away from the axle. when the block reaches the slack loop of the logging chain, the axle will pop out of the axle housing. never seen it fail.in 1969, the wife and daughter and i drove to so. cal. in a 51 chevy woody wagon(455 Olds , muncie 4 speed and a 55 chevy rear end). lost an axle bearing near the grand canyon. limped about 10 miles south of the canyon and discovered an old abandoned gas station with a abandoned 55 chevy 4 door behind the gas station. nobody around and no slide hammer to remove the 55 chevy's axle. there was a concrete block and i had a chain. now ya know the rest of the story.mike
            • Dale S.
              • November 12, 2007
              • 1224
              American ingenuity in action. Thanks dale
              • Tom P.
                • April 1, 1980
                • 1826
                Oh yes there is--------------------53-55. Essentially the exact same rear as 49-54 pass car rear!
                • Cecil L.
                  • May 31, 1980
                  • 450
                  Another way is to reverse the brake drum, reattach the lug nuts loosely and use the drum for a slide hammer. Could be rough on the stud threads, though.
                  • Rod K.
                    • 445
                    Probably ought to plan to drop the center section and replace the gasket since it's been compromised now.
                    • Chuck G.
                      • May 31, 1982
                      • 2039
                      That's the method I've used.
                      I've never tried the "cinder block" method. I haven't pulled a ton of axles in my life, but I've never had any problem popping them out using the reverse brake drum trick.
                      Chuck
                      • John N.
                        • February 1, 1975
                        • 451
                        Mike
                        Your story is unbelievable and will be unforgettable. A tech video with sound would be memorable. What did your family say about the experience?
                        Regards
                        • Mike M.
                          • May 31, 1974
                          • 8408
                          Originally posted by John Neas (171)
                          Mike
                          Regards
                          it was too damn cold coming out of the canyon for Lea or Chrissy to complain about "borrowing" the axle. regards,mike
                          • Terry D.
                            • May 31, 1987
                            • 2697
                            A lot of parts stores have that puller to rent, depending how much room you have in your garage to throw cinder blocks around it might be worth the few bucks to rent a puller. Harbor Freight also sells one pretty cheap. Just my 2 cents
                            • Keith R.
                              • August 31, 2001
                              • 675
                              Actually picked up a flange puller from Auto Zone and as long as I return it within 90 days, it doesn't cost a cent (and probably cheaper than buying a concrete block!)
                              Keith MacRae
                              NCRS #36692
                              New Mexico Chapter
                              1960 290HP FI
