69 headlight help - NCRS Discussion Boards
69 headlight help
  • Jeremy H.
    • January 1, 1999
    • 260
    69 headlight help
    Working on a 69 conv 350hp car. Headlights will not go up or down, or the wiper door for that matter. I bypassed the vacuum canister and still no luck. I put vacuum directly to the valve between the headlights, no luck. Where would I connect a direct vacuum line to each actuator to rule them in or out as a problem?
    Thamks
    Jeremy Hedges
    31711
