fuel pump - NCRS Discussion Boards
fuel pump
  • John S.
    • November 1, 1982
    • 1
    fuel pump
    looking for best options to replace fuel pump (AC 40433) for 67 small block. are they truly being rebuilt or reproduced?
    Re: fuel pump
    Paragon has correct 40433's - don't know where they get them (their #11505).
    • John D.
      • June 30, 1991
      • 875
      Re: fuel pump
      John
      How does this repro pump judge ? Are the AC letters on the side tall enough as compared to an original ? I recently installed the current AC-Delco replacement pump on my 67. It was $29, but had no AC logo or other marks on it at all.
      jd
        Re: fuel pump
        John -
        I don't know - I haven't seen one. Their description says it's an original casting, number stamping, AC logo, etc.; might be a Paul Baker rebuild - I don't know of anyone else offhand that's rebulding the "crimped" pumps.
        • John S.
          • May 4, 2008
          • 424
          Re: fuel pump
          John
          Check your email.
          John Seeley
          67 black teal coupe
          John Seeley
          67 Black/Teal
          300 hp 3 speed coupe
          65 Maroon/Black
          35k mile Fuelie coupe
          • Rick S.
            • January 1, 2003
            • 1203
            Re: fuel pump
            Here is Paragon's fuel pump purchased last year for my small block (L-79).
            Rick
            • Rick S.
              • January 1, 2003
              • 1203
              Re: fuel pump
              Here is one additional photo.
              • Henry S.
                • April 30, 2005
                • 816
                Which fitting for 40433
                I have a 327/300 1967. I just installed a 40433 fuel pump from Zip. I believe the lettering on it is GC 40433. It is suppose to be correct for SB according to the Judging Guide. It didn't come with the fitting on the inlet side that is needed to connect the rubber hose on the end of the fuel line coming from the fuel tank. It has the same setup as the one Rick posted. The only difference I could see is the letters ( his being 7E and mine I think is GC). In the LI Corvette catalog the only 300 horse fitting is for 1964-1966. There is NO fitting listed for the 67 300 horse. I found the same thing in the Paragon catalog. I couldn't find anything in the Judging Guide that spells out what fitting to use. Which fitting is correct for the 67?
                Along the same lines the guide says the pump is connected to the block by 2 recessed 7/16" recessed hex head bolts. Isn't it suppose to have a plate with 4 bolts (2 recessed as described and 2 shorter 7/16" at the bottom of the plate)? Shooter
                • Mike M.
                  Director Region V
                  • August 31, 1994
                  • 1463
                  Re: fuel pump
                  Yes, Henry. 4 bolts (2 & 2).
                  Those two recessed hex heads you describe that secure the pump to the block on original cars also have flanged collars and separate lock washers in the same diameter as the flanges.
                  HaND
                  • Henry S.
                    • April 30, 2005
                    • 816
                    Re: fuel pump
                    HaND
                    Thank you Mike. I did change the bolts out to the correct ones with the flanged collars that you mentioned. Shooter
                    • John D.
                      • June 30, 1991
                      • 875
                      Re: fuel pump
                      Hi Rick,
                      Thanks for posting the pictures. Would it be fair to say it looks like the upper casting is an original piece with a replacement lower part crimped on ? It doesn't give me a warm fuzzy feeling but if the pumps work well I may consider buying one... $150 is not cheap though as compared to a service replacement with no markings.
                      john
                      • Rick S.
                        • January 1, 2003
                        • 1203
                        Re: fuel pump
                        John,
                        I believe your assessment is correct but I am not sure. Pump has worked fine. I replaced it in the fall of 2007 when I had the engine out for a rebuild. My old pump was a non AC service replacement. I am not sure what I paid but you do get a 10% NCRS discount at Paragon.
                        Rick
