Tilt And Tele Ing. Key Buzzer Switch - NCRS Discussion Boards
    • 6961
    Ive Got A 72 Coupe That Needs A Ing. Key Buzzer Switch, With A Tilt And Tele. Steering Column, Any Ideas Of Where I Can Purchace One. Thanks Ed
  • Michael G.
    • March 2, 2008
    • 487
    Re: Tilt And Tele Ing. Key Buzzer Switch
    Ed,
    Are you sure the switch is bad? I only ask because my 71 came to me with the buzzer not working and I found a bad connection at the horn relay. There is a blade connector at the frontmost end of the relay that apparently supplies power to the buzzer. Just thought I'd mention it.
      • 6961
      Mike The Buzzer Does Work. The Column Is Apart And The Switch Is Broken - It Buzzed All The Time Even With The Key Out.
