Information On 1972 Rocker Panel With Tab On End - NCRS Discussion Boards
  • Bill E.
    • February 20, 2009
    • 38
    Re: Information On 1972 Rocker Panel With Tab On End
    Hi. Guys Thank You For The Screw Information. Bill
    • Harmon C.
      • August 31, 1994
      • 3228
      Originally posted by Jim Trekell (22375)
      If you have replaced the original rocker panels with the later GM rocker panels without the tab, would continued use of the correct screw and j-nut reduce the point loss for not having the original rocker panels with the tab?
      I would say the point loss for the panels would stay the same. If the fasteners are judged on the same line with the panels their would be dedutions for them also above the panel deduction. The correct parts installed even in this case if they are not holding anything would be lots better than missing parts. Missing parts will always get a deduction. JMHO the screw and clip should get the same credit if it is holding a tab or not.
      Lyle
