71 trans interlock system - NCRS Discussion Boards
  • Jim S.
    • August 31, 2001
    • 730
    Re: 71 trans interlock system
    Let's start with another basic question. Are we talking about a T&T column or a standard (non-adjustable) column? The locking and ignition systems are similar between the two types of columns but there are some differences.
    Installing the lock cylinder is pretty much error proof regardless of type of column. You push it in and rotate to engage the back end of the cylinder to the plastic sector. If someone has been inside your steering column head it is possible that the teeth on you plastic sector are not properly engaged to the die cast rack. There is one big tooth on the sector. That tooth must engage a big blank space on the rack. Otherwise, you will run out of rack travel. In order to disassemble the column you will need information on the standard or the T&T type column.
    I have complete disassembly and repair information at the www.corvettefaq.com websight.
    Click on Jim Shea's Steering Papers
    Click on Corvette Steering Papers
    Scroll down to either the Standard or the Tilt & Telescoping steering column sections.
    Down load Disassembly & Repair Papers #1, #2, and #3. There are Disassemlby & Repair Pics as well.
    If the problem is not the rack and sector engagement, then the next obvious thing would be adjusting the ignition switch to make sure that it is synchronized with the rest of the steering column. Adjusting the ignition switch is also covered in the above papers.
    Jim
    • Steven G.
      • November 17, 2008
      • 348
      Robert, The moving locking parts inside column, below the slotted locking plate need to be lubricated especially a car getting to be 40 years old. I use oil generiously and then finish with grease for lasting lubrication. The chrome cover on key lock has about 3/16 space from the column and the chrome cover will feel spring loaded and will almost touch the column when pressing in. This may help to identify if key lock assy. is completely engaged inward. Steering columns can be a real pain in the a.s unless you have done a couple. Steve
      • Robert P.
        • November 1, 2004
        • 66
        #18
        This is a standard column. I am going to remove the ignition cylinder. when i get to that point is there anything to look for or anything I can do to a line up the parts. thanks Bob
          • 15601
          #19
          The instructions for installing the ignition cylinder are in the 1971 AIM, UPC 6, Sheet B5. I found them while looking for the answer to a question posed in another thread.
          • Robert P.
            • November 1, 2004
            • 66
            #20
            That illustration should help. Do you know if any repairs to the sector can be done without removing the column ? I have Jim Shea's papers copied. They look like they will be a big help. Thanks Bob
