Does a 72 BB have a ballast resistor? - NCRS Discussion Boards
  • Robert B.
    • March 1, 1999
    • 43
    I would like to install a Mallory Unilite electronic ignition kit. It calls for a ballast resistor. Is there a ballast resistor built into the coil or some other place in 1972? Thanks.
    • 43218
    Re: Does a 72 BB have a ballast resistor?
    Robert-----
    There is no ballast resistor, per se, used on any 1968 or later Corvette. Instead, a special resistance wire is used. This is the wire with the light colored, fabric covering which installs to the coil. I do not know if this is compatible with a Mallory conversion, or not. However, it is compatible with the Breakerless electronic ignition system conversion.
      Bob -
      See "Figure 2" in the instructions .pdf at the Mallory link below - it shows Unilite wiring with the OEM resistance wire like you have.
      http://www.malloryperformance.com/pdf/1214M.pdf
      • Robert B.
        • March 1, 1999
        • 43
        Thanks - that tells what I need! Regards, Rob
