I am putting a 2004R in my '61 230hp pg. I need some type of adapter for it. What is the difference in the back of the engine and pg mounting styles from the '61 and earlier engines vs '62 and newer with aluminum pg? I am interested in the flex plate, starter and its mounting, and the adapter on the '62 (if any) compared to the '61. My '61 adapter appears to be basically for installing the starter. Any difference in length of input shafts or where the starter engages the flex plate? Are they both same tooth count?
