C2 hard top rear window removal help - NCRS Discussion Boards
  • Bill S.
    • January 31, 2007
    • 396
    can the window be removed without destroying the gasket? when putting it back in can you use the string method we used on the vw beetles to reinstall it?
  • Joe R.
    • July 31, 1976
    • 4552
    Re: C2 hard top rear window removal help
    Bill,
    Yes, it can be done but I've never seen a gasket that didn't need replacing. The string method is the only way I know to get one back in however if you wanted to waste a lot of time you could use a flat blade screwdriver.
    JR
    • Bill S.
      • January 31, 2007
      • 396
      the gasket is in great shape and original. but for $30 i would, should replace it. i was suprised at how easy it was to pop out the plexi. i guess swapping out all those beetle windsheilds when i was a kid paid off.
