I have an original gas pedal so I think it is. Number 3771749 AY 3.
Can someone inform if this part is judged and do they visually need to see the part number if it is judged.
The back has a teflon type white plastic piece that slides on the accelerator linkage. Is the plastic meant to run the full width of the pedal mine seems to be cut in half ( maybe it wore out and the last owner cut and removed the worn out piece ). I can buy a G.M. replacement gas pedal for next to nothing, externally they look the same. Will I get away with a G.M. replacement or should I repair the original one. Stewy
