T-10 Side Cover Identification - NCRS Discussion Boards
  • Joe P.
    • October 4, 2007
    • 209
    Appreciate any thoughts on this side cover.
    I just picked up a 1960 T-10 and looking for some help to identify the main case side cover. It looks like the correct configuration to me, only that it apears to be cast iron and not aluminum.
    Thanks in advance
    Joe
  • Stewart A.
    • April 16, 2008
    • 1035
    Re: T-10 Side Cover Identification
    Side cover is correct and the tail should be aluminium the main case should be cast for a 1960. The full alloy is 61 onwards Joe. Looks good to me.
    Stewy
    • Bill M.
      • March 31, 1977
      • 1386
      My '59 T10 (known original) has an aluminum side cover and an iron case.
      • Tom D.
        • September 30, 1981
        • 2121
        Alum side cover on mine too.
        This 1960 Corvette was 290HP (Code CS 283). The car and engine birthdays were just last month, in March.
        https://MichiganNCRS.org
        Michigan Chapter
        Tom Dingman
        • Mike E.
          • February 28, 1975
          • 5134
          Side cover should be aluminum. T-10's were used on other GM cars, Studebakers (I believe), etc. back in those days.
          • Mike M.
            • May 31, 1974
            • 8365
            all c-1 t-10's, with the exception of the VERY EARLY 57's, used an aluminum side cover. the other GM brands used a cast iron side cover in the late 50's and early 60's.mike
            • Loren L.
              • April 30, 1976
              • 4104
              I'm with the two Mikes, which (when they agree) is a very safe place. Early aluminum side covers will appear without the buttresing ribs - 1957 and part of 1958.
              • Mike M.
                • May 31, 1974
                • 8365
                "without buttressing ribs" is lawyer BS. correct terminology is "lack of gussets" ya big dummy.regards,mike
                • Tom P.
                  • March 31, 1980
                  • 1814
                  Also, isn't the oval (0) boss for the fill plug (instead of the round [o] boss) a feature of very early main cases?
                  • Mike M.
                    • May 31, 1974
                    • 8365
                    tom: all 3 of my 57 t-10's are post april 57 . i've never had the joy of examining an early 57 t-10 main case. regards,mike
                    • Stewart A.
                      • April 16, 2008
                      • 1035
                      Sorry about that I thought Joe was talking about the main case being cast and alloy must read question properly next time !!
                      Stewy
