Help ID Wheels - NCRS Discussion Boards
Help ID Wheels
  • Rob M.
    • April 30, 2003
    • 657
    Help ID Wheels
    Please help ID these wheels. I believe they are 15 x 6. Here is what is stamped by the valve stem:
    14 FL 9 M28
    Are they correct (or will they work) for a 65-67 corvette?
    Rob
    '66 327/300 Regional Top Flt
    '08 6 speed coupe
  • Rob M.
    • April 30, 2003
    • 657
    Re: Help ID Wheels
    Here's the back
    Rob
    '08 6 speed coupe
      • November 30, 1997
      Re: Help ID Wheels
      Rob -
      Can't tell you if they'll "work" without more information (offset, etc.), but they're definitely not correct; a '65-'66 Corvette steel wheel looks like the photo below, and original wheels didn't have anything stamped adjacent to the valve stem.
      • Rob M.
        • April 30, 2003
        • 657
        Re: Help ID Wheels
        John,
        Thank you very much.
        I assumed they weren't original due to the markings by valve stem. I'm wondering if they are over the counter replacements - or all wrong entirely for 66. Clearly, I'm no expert. How does one measure the offsets, etc. to know if they'll work?
        Thanks again for helping.
        Rob
        '08 6 speed coupe
        • Edward M.
          • October 31, 1985
          • 1916
          Re: Help ID Wheels
          I am fairly certain that these are early to mid 1970s Chevelle / Malibu wheels (FL code). I can't find the reference at the moment, but it should be listed in the Chevy by the Numbers book. I have a set of these on my 56 Corvette.
          I believe that it would clear disc brakes with no problem. I am thinking that these are the wheels that I see on Ebay as "cheap replacements" for 65 - 66 Corvette wheels.
          • Wayne M.
            • February 29, 1980
            • 6414
            Re: Help ID Wheels
            Ed is correct on all counts -- Colvin's book shows 15 x 6" Chevelle 1975 (maybe later as well, but his 70-75 book ends there). 0.50" offset. Compares to 0.44" for '65-6 steel stock Corvette wheel.
            I have 2 of these (one was spare on my '65 when purchased in '88; other is temporarily mounted on same car -- no clearance problems.
            • Rob M.
              • April 30, 2003
              • 657
              Re: Help ID Wheels
              Wayne,
              Thanks! What about hubcaps? Would there be any issues with them fitting?
              Rob
              '08 6 speed coupe
