T-10 advice - NCRS Discussion Boards
T-10 advice
  • Joe P.
    • October 4, 2007
    • 209
    T-10 advice
    I am about to replace my transmission with a T-10 that hasn't been in a car in over 20 years. It was shifting smoothely and working great when it was stored.
    The fluid was left in, and it has never leaked.
    Looking for tips on what to do before it sees the engine.
    Thanks.
    JP
    • 43279
    Re: T-10 advice
    Thanks.
    JP
    JP-----
    I don't think you need to do anything. However, if it was me and considering the history of the transmission, I think I'd drain the lubricant out and replace with fresh. Likely not necessary, but the lubricant is cheap.
    • Timothy B.
      • April 30, 1983
      • 5202
      Re: T-10 advice
      Joe, If there is a transmission man in your area, you may want to consider taking the side cover off and having someone look at the shifting forks and gear teeth for a opinion.
      The work involved with installing and removing if there are any issues is something to consider.
      • Ray C.
        • June 30, 2001
        • 1132
        Re: T-10 advice
        I just rebuilt a T-10 for my 61 and the O-rings for the shifting levers-forks were brittle. I would replace the rear yoke seal, O-rings for the shifting forks and speedodmeter gear.
        Good luck!
        Ray
        Ray Carney
        1961 Sateen Silver 270-HP
        1961 Fawn Beige 315-HP
        • Dennis A.
          • April 30, 1999
          • 1010
          Re: T-10 advice
          Replace the seals and check the forks....much easier to do on the bench than having leaks after a few miles....
          • Reed F.
            • May 31, 1996
            • 31
            Re: T-10 advice
            If you are going to take the T10 apart, consider replacing sliders with torque lock sliders. Makes the transmission much better, ends the typical T10 problem of jumping out of gear. The torque lock sliders are not expensive and easier to put in when the tranny is already out.
            Reed
            • Tim S.
              • May 31, 1990
              • 715
              Re: T-10 advice
              Joe
              In addition, I would treat the trans like it is fresh. What I do with a fresh trans, is run it up and down through the gears for about 15 minutes with the car in the air. It allows lubricant to work into every portion of the trans without a load on it. Hope this helps
              Tim
              • Joe P.
                • October 4, 2007
                • 209
                Re: T-10 advice
                Originally posted by Tim Schuetz (17356)
                Joe
                Tim
                Tim, I saved the diagram with dimensions, but i cant figure how to upload the pic, so i copied it into a document, but the file is too big.. Sorry i cant post it. If you PM me your email adress I can forward it.
                Here is the original post:
                C1 Transmission Removal September 14th, 2004, 01:41 PM
                • Richard G.
                  • April 30, 1991
                  • 68
                  Re: T-10 advice
                  Where would one purchase the 'torque lock sliders'?
