TCS Solenoid 1970 - NCRS Discussion Boards
TCS Solenoid 1970
  • Les G.
    • December 5, 2008
    • 158
    TCS Solenoid 1970
    How do you test out the TCS Solenoid on a 1970 350/350? If it is bad does anyone sell parts to repair? Who rebuilds them?
    • 6941
    Re: TCS Solenoid 1970
    Les,
    There Is A Easy Way To Test Solonoid, Use A Test Lamp, One Side Will Be Power The Other Ground, Take The Test Lamp And Touch The Ground Side With The Test Lamp,this Will Act As A Ground And Solonoid Will Click, Next Start The Car And Ground The Solonoid Again With The Vaccum Hose Off At Dist. Vaccum Should The Flow As You Ground Test Lamp. Hope This Helps Ed
    • Robert M.
      • June 30, 1992
      • 120
      On the 1970 350/350 hp (L46) vacuum is supplied to the distributor when the electrical circuit is broken (off), and vacuum denied when electrically enabled, (turned on). Vacuum is sourced on the single in-line port side, and vacuum to the distributor is vented off, from the opposite in-line port adjoining the right angle port going to the distributor.
      JACK will jump in here, he has a really good way of explaining the TCS system, as evidenced by his fine article in the recent Restorer.
        Ah heck, TCS and CEC were pretty much the same thing with the one year only CEC being a smart combination of parts (single solenoid that did both the vac switching and curb idle RPM control). Now that Vinnie unearthed my ages old article, it's in NCRS 'public domain' and I don't need to comment further...
        • Dennis D.
          • March 1, 2000
          • 1071
          Jack straightened me out too. But the easiest way to test if the system is functioning before diving into the components..... start and let warm up to temp. With the clutch held to the floor, shift into 3rd or 4th gear. Idles rises, sytem A-OK.
          Robert is correct, temp overide not withstanding, Shifting to 3rd or 4th grounds the trans switch, disabling the TCS. There is no vacuum at the rear carb to solenoid hose, as this acts as the vacuum vent, or break.
