AZ wheel date codes for dummies - NCRS Discussion Boards
  • Kevin G.
    • January 31, 2005
    • 1074
    I'm the dummy! Can someone please help decode these wheels?
    1. K 1 6 11 stem 16AZ
    2. K 1 7 8 stem 22AZ
    3. K 1 95 9 stem 8 AZ
    4. K 1 3 9 stem 20AZ
    K= Kelsey
    1= Chevrolet
    next ?(6,7,95,3)
    11,8,9,9= month
    16,22,8,20=day
    AZ= 70-72? 15x8 Corvette wheel
    TIA,
    Kevin
  • Don L.
    • August 31, 2005
    • 1005
    Re: AZ wheel date codes for dummies
    Kevin...think it works like this:
    K = Kelsey Hayes (manufacturer)
    1 = Kelsey plant #
    1 or 2 digit stamp = year
    (valve stem hole)
    1 or 2 digit stamp = day
    AZ = type/size (AZ is 15" dia. X 8" wide)
    your numbers as follows:
    (19)76 Nov 16th
    (19)77 Aug 22nd
    (19)95 Sep 8th
    (19)73 Sep 20th
    Don Lowe
    NCRS #44382
    Carolinas Chapter
    • Kevin G.
      • January 31, 2005
      • 1074
      1 = Kelsey plant #
      (valve stem hole)
      (19)76 Nov 16th
      (19)77 Aug 22nd
      (19)95 Sep 8th
      (19)73 Sep 20th
      Thanks Don! It was the (95) that I couldn't understand. The AZ's were used for what years?
      • Don L.
        • August 31, 2005
        • 1005
        Yeah, think they stamped the '95s with the 2 digit code to dicern between '75s, '85s (don't know if 85s were stamped with 1 or 2 digit code) and '95s.
        Where are you in the DE valley? I grew up in Wilmington.
        Don Lowe
        NCRS #44382
        Carolinas Chapter
        • Kevin G.
          • January 31, 2005
          • 1074
          These wheels sound like they will be perfect for my driver 72!
          I'm about two hours north of Wilmington, in Buckingham, Bucks County. We do have several members from DE!
          Thanks again Don,
          Kevin
          • Jeff A.
            • December 31, 1999
            • 312
            what are these YS wheels?
            and these YW wheels?
            They are not corvette wheels - so what are they from?
            My Cars
            • Cecil L.
              • May 31, 1980
              • 449
              YS= 69-70 Chevrolet "B" body w/disc brakes, replaces "DC",
              15x6 JK, .06 offset.
              YW=69-70 Chevelle Pass Rally w/DB, replaces "XB", 14x6 JJ, .88 offset.
              • Jeff A.
                • December 31, 1999
                • 312
                That can't be right? - they are all 15" wheels.
                I suspect they are later then 1970 wheels.
                one pair is 15X7 - the other pair is 15X8
                My Cars
                  • November 30, 1997
                  Kevin -
                  The "AZ" 15x8 rally wheel was the standard wheel on Corvettes from 1969-1982.
                  • Cecil L.
                    • May 31, 1980
                    • 449
                    Then I suspect his info may be incorrect. As far as my references go, the only 15x8 rallys through 75 were AZ's. He says the YS wheels are 15x7 and my references say 15x6. I don't see a Y in the pic of the "YW" wheel and I would suspect it may be an FW which is a 15x7 not 15x8. JMHO, who knows?
                    • Jeff A.
                      • December 31, 1999
                      • 312
                      Yes - took a closer look FW
                      one pair is 15x7, the other is 15x6.
                      My Cars
