Silver Caulk for windshield header - an update - NCRS Discussion Boards
    • 11659
    Re: Silver Caulk for windshield header - an update
    I still think you'll be sorry...
    • Greg H.
      • June 2, 2008
      • 254
      You're probably right Patrick, but I want to replace this material without dis-assembling for now. Besides that, I really want to find a material that most closely resembles what was put on originally. The original was not painted over so I want to avoid doing that. From the look of how mine was applied it looks more like a putty than a caulk so I'll keep looking while I chip away at the old stuff. I decided not to try the sanded caulk but have found an exterior window caulk that is made to match aluminum. The color is even closer to the under-side of the original chip.
        • 11659
        #18
        Note my previous comment about acids in caulk. Don't say I didn't warn you.
        The original stuff is silver colored "dum dum" or Strip-Calk. So, if you want to stay "like original" you can either try and color some "dum dum" to silver, or just color the exterior of it like I did. You can't tell.
        I used a dental probe (well, actually an old one from a gross anatomy dissection kit) to push the dum dum into the crevice. Worked well, but got a blister on my thumb.
        Patrick
        • Bill C.
          • July 15, 2007
          • 904
          #19
          Listen to what Patrick is saying - caulk HAS acid in it (somewhere).
          It will cause corrosion ---
          I have used the 3M strip dum-dum and it works just right. I think it will give you a better seal when pushed firmly into the crack. I did a tinting somewhat like Patrick did, looks good.
            • 6948
            #20
            Pat, I was looking at a original 68 conv. last month, was looking at his windsheild piller with the top down, its has like a silcone gasket maker type sealant(It appears to be silver) at the areas where the piller moulding joins the upper windsheild moulding. the other areas I believe that it the 3m caulking,I was a line mechanic back in the 70s for chevrolet, I seem to remember that 3m use to make the caulking in a few shades, I believe that there use to be a light gray color along with the black.
            I did many a weatherstrips in my days, GM did not know how to seal a car up from water or air leaks,or oil leaking .
            • Greg H.
              • June 2, 2008
              • 254
              #21
              Guys,
              I really appreciate the advice and experience here. I will do more research, but I'm still determined to find something that looks as much like what is there. I saw a car at the recent chapter meet which I believe used the method described above but I was not pleased with how it looked. Is it me or do the edges appear a little ragged?
              The stuff GM used clearly did not do the job but it looks good
              By the way, I have not heard the term dum dum (other than a city in India). Is there another name for it? Plumbers putty?
              GM had to have something that flowed easily and was applied like a caulk and worked in by hand. That's what I want to use.
                • 11659
                #22
                Guys,
                Greg,
                I've got a Bowtie car here, and I've got the 72 I'm working on. Both were/are available for my inspection. In addition, I see your pictures attached of your "original material."
                Using the 3M Strip-Calk (i.e. dum dum) plus the fabric paint gave an appearance that is exactly like what the factory did. It could be applied by hand, and if silver Strip-Calk were available I'm 100% sure it could be applied by hand and would be the original type material. I purposely stuffed as much Strip-Calk (20+feet) in the 72 project as I could because I am doing the car for a client and I did not want one (1) drop of water to get through. And, I'm anal so I wanted the appearance to be just right.
                In short, current black Strip-Calk + silver fabric paint = "original" material of silver dum-dum (or Strip-Calk or similar). If you find silver dum-dum/Strip-Calk/etc then you've got the original material which was not a caulk and cannot be replicated by caulk.
                Patrick
                • Greg H.
                  • June 2, 2008
                  • 254
                  #23
                  Thanks again Patrick. I'm a little slow but coming around. I'll get some dum dum and try it out. I'm going to have quite a supply of gray shade sealants on the shelf.
                    • 15613
                    #24
                    Are you saying that 3M no longer makes the gray strip caulk? Oh no ... tell me it ain't so.
                    • Greg H.
                      • June 2, 2008
                      • 254
                      #25
                      Well the Norton Company does:
                      Part # 82761
                      The description reads a lot like the 3M description.
                        • 11659
                        #26
                        Don't be afraid to stop by your local Michaels craft store and use the products I tried early in the thread.
                        Patrick
                          • 11659
                          #27
                          If they ever made it, I've never found it.
                          All I could find earlier this year - and looking today - is black.
                          Wish I'd know about that Norton stuff.
                          Hey Greg.....
                          Patrick
                            • 15613
                            #28
                            Oh yes they made/make it in gray. I'll have to go to the garage to get the part number. I last bought some about 3 to 5 years ago.
                            Looks like it is only black now.
                              • 11659
                              #29
                              Yup.
                              I'd love for someone (Greg?) to buy some gray Norton stuff and let us know if it's correct.
                              Patrick
                              • Pat M.
                                • April 1, 2006
                                • 1579
                                #30
                                I found and used 3M gray caulking about a year and a half ago. Looks great, sealed well, and judged well. I thought I still had the left over tube, but I can't find it, just in time for it to no longer be available.
