69 shim marks - NCRS Discussion Boards
69 shim marks
  • Hank H.
    • July 31, 2006
    • 76
    69 shim marks
    My 69, after a body off restoration, did not receive shim marks from the restorer. It is a factory side exhaust car, which makes me believe I only need to add marks at the number 1 and number 4 positions. The restorer claims to have placed the original number of shims back on the frame at all locations. At the number 4 position, I have 6 and 7 respectively for left and right. Does this sound OK from a judging standpoint? Should the marks on the frame, which I believe are arabic for 69, match what is actually there? Please advise whether I should remove the side exhaust and place marks at the number 2 and 3 positons, as well as comment on the shims I have at number 4 position. By the way, the number 1 postiion has 2 on each side. thanks
